CEL: P0141 Secondary Heated O2 Sensor
Yesterday my CEL came on so I went to Auto Zone to find out why. They said code P0141 came up (Secondary Heated O2 Sensor; Heater Circuit Malfunction). I've got several questions:
1. Does a "heater circuit malfunction" mean that I need to replace that O2 sensor or is the "heater circuit" seperate from the O2 sensor?
2. Roughly how much am I looking at to have this replaced?
3. This summer I had to replace my ECU due to my ac condensation drain being clogged and it overflowed into the ECU. I have read that this O2 sensor is connected to/talks with the ECU. Could these issues be realated? (ie: could faulty install of the new ECU led to the O2 sensor heater circuit frying out?)
4. I've read that this particular sensor is in/near the catalytic converter. I know that my catalytic converter heat sheild was failing and my muffler shop secured it with some quick welding. Could failure of the heat shield lead to the O2 sensor heater circuit fail? (If I don't fix this problem will the problem with the O2 sensor happen again?)
Thanks for any help you're able to provide!
Re: CEL: P0141 Secondary Heated O2 Sensor
1. Normally the O2 sensor is the part triggering the trouble code. The same code could come up related to something in the circuit, such as one of the wires cut; but, generally it is the sensor needing replacement.
2. Depends on whether your car is California or not and whether you will do it yourself.
3. Probably not. You have a new ECU, a short for a sensor may damage the ECU, not usually the other way around.
4. Probably not, unless the O2 sensor wired got chafed and eventually cut.
The Honda O2 sensor (non-Calif) part number is 36532-RAA-A02. Denso is usually the Honda OEM part, so it doesn't need to be bought from the dealer. Honda list price for the part if $92.05, internet discount price is approximately $67. You may be able to find it cheaper.
Denso is better than Bosch for Honda. You may want to read this thread:
https://honda-tech.com/forums/honda-accord-crosstour-2003-2012-118/2005-accord-lx-4cyl-2-4-engine-o2-sensor-2464806/
Standard labor should be around 0.4 hours, so depending on your area's shop rates, use that as a reasonable estimate. The only thing is some shop try to charge a diagnostic fee, which they may or may not apply toward the repair. Some shops won't if you already tell them you got that code and want the O2 sensor replaced. Talk to them first before agreeing on any work.
be professional
Thanks for the help guys. I talked to my mechanic, told him the code that came up and he said I don't need to worry about it for a while. He said something about sometimes these will fail to warm up once and that will turn on my CEL. He said if I don't need an emissions test anytime soon that its something I can put off for a while. Any thoughts? I have read that this may reduce my fuel economy. Will this be drastic?
Thanks again for all your help!
be professional
You won't have any way to know if the PCM stores new error codes during that time though, since the light will already be on.
A Denso 234-4797 or Bosch 15409 sensor isn't expensive. If you're going to have to eventually replace it anyway for emissions compliance, you might as well do it now.
anothersickhatch
05-15-2004 10:22 PM
