ECU Code # 54..
Old Jan 11, 2004 | 12:05 PM
plusONE jboy's Avatar
Default SRS ECU Code # 54..
EDIT: I read the code wrong it was coming from the SRS light..
Code #54
Modified by 5thgenh4tch at 9:33 PM 1/11/2004
Old Jan 11, 2004 | 12:13 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: ECU Code # 54.. (5thgenh4tch)
Check out the distributer. How old is the car? If it has high mileage, do a cap/rotor replacement.
Note: I always get confused with the Crank Speed Sensor and the Crank Angle Sensor. I'm almost positive the one you're talking about is with the distributer.
Old Jan 11, 2004 | 12:32 PM
Default Re: ECU Code # 54.. (shamoo)
I actually checked again, and its actually the srs light throwing that code..
I am confused..
Old Jan 12, 2004 | 04:15 AM
JimBlake's Avatar
ABS code 5 4 is right-rear wheel lock, according to my list ('95 Helm book).
That's different from 4 4 which is the RR wheel speed sensor.
I don't have the book with me right now, so I don't know what you're supposed to do to fix it...
Old Jan 12, 2004 | 06:17 AM
Default Re: ECU Code # 54.. (JimBlake)
Thanks.. theres a start.
I am just curious, does the ABS system allow you to reset the light, w/o the problem being fixed?
Old Jan 12, 2004 | 09:41 AM
bump
Old Jan 25, 2004 | 10:06 AM
Does the ECU allow you to reset the Light without fixing the problem?
Old Jan 25, 2004 | 05:01 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenh4tch &raquo;</TD></TR><TR><TD CLASS="quote">Does the ECU allow you to reset the Light without fixing the problem? </TD></TR></TABLE>
It depends how you reset it. If you just take the negative battery terminal off of the battery/remove ECU fuse for a few minutes, it won't do anything.
If you actually reset it with an OBD program (for example one that plugs into the service port), then it will go away. However, as soon as you turn on the car/run it for a while, and if the problem is still there, the light will turn back on.
classciv
May 8, 2006 10:43 AM
john d
Oct 7, 2004 03:43 AM
ozzyman
Oct 3, 2003 12:00 PM
Yellow00TypeR
May 22, 2003 07:36 AM
