ABS light!!!
Old May 21, 2003 | 08:11 PM
Yellow00TypeR's Avatar
Default ABS light!!!
I just put a set of stainless lines on my R and bled the brakes and now the ABS light is on. Anyone else have this problem???
Old May 21, 2003 | 08:14 PM
b19coupe's Avatar
Default Re: ABS light!!! (Yellow00TypeR)
Short the SCS connector and see what ABS code you are getting.
Old May 21, 2003 | 08:16 PM
Default Re: ABS light!!! (b19coupe)
it was flashing code 11 and 13
Old May 21, 2003 | 08:31 PM
b19coupe's Avatar
I can check the manual tomorrow at work and tell you what circuits/components to look at.
Old May 21, 2003 | 08:37 PM
I have the service manual right here. I already looked the codes up and found out what they were, I just don't really want to go through all that troubleshooting **** unless I absolutely have to. I just wanted to see If anyone had the same problem or something similar that could help. Thanks for the offer.
Old May 21, 2003 | 08:39 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Reset the ECU and see if it comes back on.
Old May 22, 2003 | 07:36 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellow00TypeR &raquo;</TD></TR><TR><TD CLASS="quote">it was flashing code 11 and 13</TD></TR></TABLE>
You may have broken the wires for your wheel speed sensors.
Code #11- r/f wheel speed sensor.
Code #13 l/f wheel speed sensor.
The wire will appear intact, but inside it's broken.
Unless you unplugged the sensors and forgot to plug them in.
94BlueGSR
Oct 21, 2006 12:06 PM
Mad Money
Jan 9, 2006 05:20 PM
mt23vtecbb2
Jul 18, 2005 08:54 AM
integrasi
Jan 4, 2004 03:08 PM
ozzyman
Nov 18, 2003 05:51 PM
