EASY timing question
Old Apr 25, 2002 | 05:02 PM
KooK's Avatar
Mustang Sally
Default EASY timing question
What would give me more power on my stock engine? 16btdc or 18btdc? Or should I just go in the middle there and hit 17 Thanks guys!
Old Apr 25, 2002 | 05:52 PM
Audipwr1's Avatar
Default Re: EASY timing question (Tapeworm)
u have to dyno, each car to their own, too much timing=bad for engine
Old Apr 25, 2002 | 05:54 PM
KooK's Avatar
Mustang Sally
Default Re: EASY timing question (Audipwr1)
ok... so 16BTDC is what they set stock correct? I'll just hit that. Thanks!
Old Apr 25, 2002 | 07:13 PM
t's Avatar
t
Stock is 16 + or - 2,
so 14, 15, 16 17, 18 all will be fine and within spec.
Old Apr 25, 2002 | 08:17 PM
SIK IN DA HED's Avatar
New User
Default Re: EASY timing question (t)
advancing it is bad for your engine. advancing it +1 or +2 isnt pushing it too far.. but i would be cautious. run higher octane gas if you do that.
Old Apr 25, 2002 | 08:26 PM
Jesse H's Avatar
Default Re: EASY timing question (dlplayboy)
GSR already requires premium gasoline, so advancing the timing on a healthy motor is a win-win scenario.
Old Apr 25, 2002 | 10:31 PM
dubster99's Avatar
Default Re: EASY timing question (Jesse H)
Advancing the timing isn't bad for the engine as long as you arent detonating, by running higher octane fuel.
Old Apr 26, 2002 | 05:19 AM
PnX-R's Avatar
I had one of my brother-n-law's friend advance my timing to 18.. All three of them said that it would be good for the GSR as long as I run 93oct gas. But do as you wish.. I only did it because their friend says that it was good for the car. But what does he know??.. He's only got a 13sec LS/VTEC ALL Motor in a 2nd Gen Teg... (That's a good enough reason for me!)
Old Apr 26, 2002 | 05:37 AM
neo1z's Avatar
Default Re: EASY timing question (PnX-R)
18 is fine, itll be quicker
Old Apr 26, 2002 | 05:44 AM
maggsgsr's Avatar
Default Re: EASY timing question (neo1z)
I've tried 17 18 and 19.They all feel the same to me but it does feel better and has more mid range tq,it was at 14.5.No problems i run sunoco 94 at al times,but it gave the car well needed mid and low range tq.I've been running at 17 for about a month.
Old Apr 26, 2002 | 09:43 PM
t's Avatar
t
Default Re: EASY timing question (maggsgsr)
Advance the timing as far as it will go until it detonates, you will be surprised how far it goes especially with only simple bolt-ons
Old Apr 26, 2002 | 10:28 PM
ken-shin's Avatar
Sorry guys, how to adjust the timings?
any hp or instructions thanks?
Old Apr 26, 2002 | 10:46 PM
OneThirtyEight's Avatar
Default Re: EASY timing question (ken-shin)
3-5 HP by advancing timing usually.
Great instructions, you WILL need a timing gun.
http://www.c-speedracing.com/howto/timing/timing.html
Old Apr 27, 2002 | 08:51 AM
red97gsr's Avatar
Go ahead and set it at 18deg. I've been running at 18deg for 2.5years now. It's within spec and you should have no problems.
yaya
Mar 18, 2004 10:08 PM
X2BOARD
Mar 16, 2004 04:00 AM
SuicideSlide
20
Jan 5, 2004 07:36 AM
Ladies Man
Jun 15, 2001 06:58 PM
