e-brake handle problem
Old Nov 28, 2005 | 09:13 PM
chinaski's Avatar
Default e-brake handle problem
its nothing too major, just more on the annoying side. a few days ago my ebrake stopped clicking when i pulled it up, it doesnt stay in place unless i hold the button down while i pull up the lever. anyone had this or know how to fix it?
Old Nov 28, 2005 | 09:19 PM
ernald711's Avatar
Default Re: e-brake handle problem (GeeSeR96)
try adjusting the screw that adjusts it. maybe the tension got loose somehow. check to make sure everything is still connected as well. i didn't get if your ebrake isn't working. you said it still stops the car rite, just not clicking?
Old Nov 28, 2005 | 09:33 PM
chinaski's Avatar
yeah it stops the car and everything it just doesnt click anymore, thanks for the input ill go check my repair manual for those screws to adjust it.
Old Nov 28, 2005 | 09:47 PM
ernald711's Avatar
Default Re: (GeeSeR96)
i'll help you out. remove your center armrest and it's the screw in between there. you can't miss it cause it's located on the cable. and it clicks every turn in either direction.
Old Nov 28, 2005 | 11:32 PM
.M.'s Avatar
.M.
Default Re: (ernald711)
yo u gotta modified drifter e-brake for da integra. it probably aftermarket but it work good when u try to slide da car in da mountain touge's in da bay area
Old Nov 29, 2005 | 08:00 AM
Vi3tboy's Avatar
i had that same exat problem last week!!! your pin might be broken or your spring might be shot also. mine came up and stopped the car but wouldnt click or stay up. sucked cuz i have a compustar w/ remote start. but you might be lucky like i was. the pin was just outta place and all i had to do was dink around with it for a bit and it it just worked. just push the button and fiddle around with it. if that doesnt work take it apart to see if your spring or pin is still good.
x4and3r1991
Mar 10, 2012 04:19 PM
Say Anything
Aug 22, 2011 09:23 PM
djgruesome
Feb 21, 2005 10:56 AM
LsBoy
Jan 7, 2005 10:25 AM
SIK IN DA HED
Mar 10, 2003 10:34 AM
