Drying water/condensation in headlight.
Old 08-29-2015, 11:43 AM
B_Swapped93's Avatar
Default Drying water/condensation in headlight.
I'm not concerned about fixing it rather drying it up as i'm selling this car, it happened when I was clay baring it. Constantly soaking water and cleaner to lube the clay as I did the hood and then power washed the car. There's only one little opening the size of a h1 bulb it's lessened since I gave it some air but I need something faster, a hair dryer?.
Old 08-29-2015, 02:27 PM
wunfstgsr's Avatar
Default Re: Drying water/condensation in headlight.
Try a heat gun or blow dryer, mask off the surrounding paint with tape before hitting it with any heat. Worth a shot.
Old 08-31-2015, 06:23 AM
EnjoyTheRideDC2's Avatar
Hair dryer would work if you were blowing the air in from behind. Dont use a heat gun. Not sure if it'll work too quickly blowing the lens area. Taking the car for a nice drive or letting it sit in the daytime sun should dry the condensation easily.
Old 08-31-2015, 08:25 AM
Airing it out in the warm garage worked/driving it without the bulb, hair dryer was dubious just cause of the narrow slot.
Hellzcivic
Honda Civic (2006 - 2015)
16
11-22-2006 06:18 PM
werksberg
Welding / Fabrication
02-15-2006 11:24 AM
rashidg
12-18-2005 09:15 AM
matto2413
02-19-2005 07:40 AM
GruvyTune
12-11-2001 04:00 PM
Quick Reply: Drying water/condensation in headlight.
