DRIVERS DOOR WINDOW
Old Dec 16, 2013 | 04:56 AM
O2BESOHUGE's Avatar
Default DRIVERS DOOR WINDOW
Its like I have a ghost in the car! Sometimes the window will roll up and down fine and other times it wont. I can be driving down the road and all the sudden it goes down by itself!
Would that be just the swith controller going bad? Anyone else run into this?
thanks guys!
Jay
Old Dec 17, 2013 | 04:51 AM
O2BESOHUGE's Avatar
Default Re: DRIVERS DOOR WINDOW
of all the integras out there, no one has had this happen?
Old Dec 17, 2013 | 05:33 AM
m4xwellmurd3r's Avatar
Never had the issue but it sounds like your switch is grounding out or something. Time to pull the door panel and see if you have any bare wires.
Old Dec 17, 2013 | 11:03 AM
BERT-O's Avatar
Like he said, but mine did that but it was the motor that went out! Run tests on the switch, etc. Its all over on this forum, simple search pops up.
Old Dec 17, 2013 | 12:05 PM
safedriver's Avatar
x
Old Dec 18, 2013 | 12:12 PM
O2BESOHUGE's Avatar
THANKS! WHERE DID YOU GET THE DIAGRAMS?
Old Dec 18, 2013 | 03:14 PM
safedriver's Avatar
I got it from the Honda Tech Marketplace, about 10 years ago, for $30ish .
These are a couple of pages, from the Integra Electrical Manual. I don't have it in front of me, but I'll add the title later.
Nice big schematics, right?
Old Dec 18, 2013 | 05:40 PM
fcm's Avatar
fcm
Old Fart
If the window rolls down by itself. the problem will most likely be the main window switch.
Power windows in our cars are polarity reversing ground at rest, so a short will either do nothing or blow a fuse, because it is the drivers window I suspect the controler unit, [auto down relay] in the master switch is bad.
Replace the master switch and problem should be solved. 94
Old Dec 22, 2013 | 05:41 AM
safedriver's Avatar
The name of my manual, from which I posted the diagrams is:
Acura Integra Electrical Troubleshooting 98 - 00
I've never bought anything from this member, but he is listing each of the door control switches, for $25
See Entry #49, the eighth item.
https://honda-tech.com/forums/showth...3182688&page=2
Old Dec 22, 2013 | 07:55 AM
fcm's Avatar
fcm
Old Fart
A power window switch, [Multiple] is $13.95 at a PicknPull. 94
Old Dec 23, 2013 | 07:02 AM
O2BESOHUGE's Avatar
THANKS GUYS!
Joey Mitchell
Oct 18, 2018 04:59 AM
scclark
Honda CR-V & Element
Aug 29, 2016 05:38 PM
Boss727
Mar 15, 2014 08:04 AM
JdmoscarEM1
May 10, 2012 06:15 AM
:jdmshmaydm:
Aug 31, 2010 07:34 AM
