Help with OBDII to OBD1
ok i have 01 gsr if i swap to obd1 then can i just get the obdII to obd1 conversion harness or is there a difference like obdIIa and B. I absolutly have to change manifolds right?? if i do the swap how do i access codes and will a p28 or p30 run my car with out chip, hondata uber, or tuning till i can save up to get these
you will need the obd2b to obd1 conversion harness....you shouldnt have to change the manifold...and theres a plug on the passenger side right above the ecu where you can run a jumper wire to check codes...
you can use a factory obd1 vtec computer. the p28 will flash a cel for cam angle. the p30 wont activate the secondaries. try to find an obd1 p72 if you want to run a factory program computer w/ your stock mani.
all the computers you can run are: obd1 pr3, p30, p72, p28, p13, p61... and i'm sure theres a few others like a p08 and stuff.
the p13 will run the secondaries, but its for an h22 and i would run it w/ some sort of piggy back so you can adjust pulsewidth.
the p28 i'd have chipped so you can get past 7500.
best advice is: factory program, use an obd1 p72.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmteg01 »</TD></TR><TR><TD CLASS="quote">i have cams and i want to switch the manifold so p30 with hondata s100 will work no CEL RIGHT?
Modified by jdmteg01 at 7:00 PM 8/17/2004</TD></TR></TABLE>
correctomundo
And since your car is a 01, its considered obd2B, so make sure you get an obd2B or version II-to- obd 1 conversion harness when you order it.
correctomundo
i'm not flamin... cool dude. go for a p30 or a p61 or an obd1 pr3. whichever you can find
. a chipped p28 is the most common thing to use and the easiest to come accross. i just saw someone on HT, name was like ih8ricerz or something close to that, sells socketed p28's w/ 2 programs of your choice for 185. then you could piggyback a hondata s200 on top of that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 »</TD></TR><TR><TD CLASS="quote">i'm not flamin... cool dude. go for a p30 or a p61 or an obd1 pr3. whichever you can find
. a chipped p28 is the most common thing to use and the easiest to come accross. i just saw someone on HT, name was like ih8ricerz or something close to that, sells socketed p28's w/ 2 programs of your choice for 185. then you could piggyback a hondata s200 on top of that.</TD></TR></TABLE>
and that would be me
sorry to jack...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">
had to help you out, i'm thinkin of askin you about one soon
</TD></TR></TABLE>had to help you out, i'm thinkin of askin you about one soon
