Door switch/alarm problems
Old Aug 24, 2005 | 06:03 PM
Danziver's Avatar
Default Door switch/alarm problems
I am currently having problems with my alarm going off for no reason and sometimes not letting me disarm it. I am pretty sure it is the door switch, i searched and there wasnt much info on the subject. Has anyone had this problem, any reccomendations?
Thanks
Old Aug 24, 2005 | 07:26 PM
mpallens's Avatar
Default Re: Door switch/alarm problems (Danziver)
What brand and how old is the alarm?
Old Aug 24, 2005 | 09:46 PM
White cracker yeehaa's Avatar
Is your battery low on the car...sometimes if the battery is low it will turn off mess up things..check the battery to the remote, that might be low too for not letting you disengage it.
Old Aug 25, 2005 | 03:54 AM
Danziver's Avatar
Default Re: Door switch/alarm problems (mpallens)
Scytek Its a brand new alarm and i had the same problem with my old one. My battery is charged and my remotes battery is too. How much would door switches cost at acura?
Thanks for the replies
Old Aug 25, 2005 | 07:10 AM
mpallens's Avatar
Who installed the alarm? Bad door switches will not cause the alarm to not respond to the remote. They will cause intermittent issues with the alarm going off. Honda/Acura switches are known for going bad.
Old Aug 25, 2005 | 07:33 AM
Danziver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mpallens &raquo;</TD></TR><TR><TD CLASS="quote"> They will cause intermittent issues with the alarm going off. </TD></TR></TABLE>
I am having that problem too. A reputable local shop installed them.
Old Aug 25, 2005 | 09:32 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
check your door triggers...they could be corroded or getting old and not keeping the trigger anymore. mine on my DA have done that. I need to replace them.
Old Aug 25, 2005 | 11:02 AM
Danziver's Avatar
Default Re: Door switch/alarm problems (DAantagonist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">check your door triggers...they could be corroded or getting old and not keeping the trigger anymore. mine on my DA have done that. I need to replace them.</TD></TR></TABLE>
Ill do that. Im sure they are the problem now.
chriskinlaw
Dec 29, 2018 04:25 PM
menappi
Audio / Security / Video
Nov 18, 2006 01:32 PM
VoltageBlue01
Apr 9, 2006 07:28 AM
nY's FiNeSt
Aug 12, 2003 09:48 PM
threatcon13
Jun 9, 2003 07:03 PM
