alarm trouble
Old Nov 16, 2006 | 06:24 PM
menappi's Avatar
Default alarm trouble
ok so i got a viper 300 esp, had everything installed and was working fine...disconnected the battery, reconnected and now im getting these problems..
-i connect teh battery
-led starts blinking prob 3x normal speed, with doors open or closed.
-if i try to arm/disarm, the alarm starts to go off, siren seems to be at maybe half volume or something...not as loud as ive heard. also when the siren is going off, the led blinks at the normal rate it seems, then when disarmed it blnks fast.
-so then i have to disarm it. if i try to turn the key to ignition, the alarm goes off.
-if i just leave it as it is, after about 30 seconds of the led blinking fast, the siren goes off.
ahh help, everything was working fine until i hooked up my passanger side door locks in my crx. i added the actuators and the driver side was fine, then i connected the passanger side and now its doing this, only after i disconnected the battery. also note that the door locks dont open or close now that this is happening.
Old Nov 17, 2006 | 02:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: alarm trouble (menappi)
So I understand, you had a door lock actuator in the drivers door and it was working along with the alarm, but you then connected up another actuator, [pass. side] and now nothing seems to work, is that correct?
1- How are the door lock actuators hooked up to the alarm?
2- Have you tried a "quite power up" before connecting power, [batt.] turn ign switch to the run position? 94
Old Nov 17, 2006 | 07:41 PM
menappi's Avatar
figured it out bad grounds, thanks to wrx-killer-Sti eater
Old Nov 18, 2006 | 01:32 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
np
chriskinlaw
Dec 29, 2018 04:25 PM
rm_accord
Jan 7, 2012 04:06 PM
BuBBa y0!
Audio / Security / Video
Jun 4, 2009 12:37 PM
smlyjo
Acura TL, RL & ZDX
Nov 6, 2002 09:17 PM
