door panel help
Old Oct 4, 2005 | 12:42 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default door panel help
my door panel wont come off all of the way. i was wondering if anybody knows how to completely take the panel off to fix my window crank. i have everything the haynes book says to take off, then it says to pu;; up but it wont come out; or is this as far as it goes. this is the passenger door. need help
thanks
Old Oct 4, 2005 | 12:48 PM
Monkey Z.'s Avatar
pull out to release the plugs then lift up (kind of hard) because there are clips holding the panels to the metal on the door
Old Oct 4, 2005 | 12:50 PM
turbob16ef's Avatar
Default Re: (Monkey-DA)
so i just pull towards me and then pull up
Old Oct 4, 2005 | 01:07 PM
turbob16ef's Avatar
Default Re: (turbob16EF)
that is not working.
the panel is loose just not coming off up by the window seal. do you take the window seal off then pull up. need suggestions or expierence
Old Oct 4, 2005 | 01:14 PM
turbob16ef's Avatar
Default Re: door panel help (turbob16EF)
need help
Old Oct 4, 2005 | 02:55 PM
txracer's Avatar
use a flat head screw driver get it under the door and carefully go around the edge of the panel when you find a clip pry it towards you and then lift up with the other hand
casper.hughes
Oct 12, 2008 06:33 PM
integracura
Dec 17, 2007 02:06 PM
JimmyAtlantis
Sep 29, 2005 08:00 AM
babyviper97
Jan 10, 2003 05:14 AM
blkonredcivic
Oct 9, 2002 05:18 AM
