Door lock problems
Old Oct 25, 2001 | 02:44 PM
E Swift's Avatar
Default Door lock problems
Has anyone ever had problems with their door locks on Gen 3 Integras? Today, I tried locking my doors, but, the driver side won't lock. It seems like it gets stuck. The passenger side locks though. I sprayed some WD-40 into the lock hole, and it works, but, not everytime. Anyone else had this problem? What did you do to fix it?
Old Oct 25, 2001 | 03:17 PM
ACURACY_VTEC's Avatar
New User
Default Re: Door lock problems (420TegLS)
i had the same problem but i don't know how i fixed it.. i took off the door panel didn't see anything wrong, so i put it back together and it's working fine. it's been ok for about 2 months.
Old Oct 25, 2001 | 03:20 PM
RacingE_Teg's Avatar
You have to hold the inside door handle in the open position when locking the driver's side. I guess it's some sort of security feature so you can open the door in case you forget your keys.
HTH.
Old Oct 25, 2001 | 03:25 PM
New User
Default Re: Door lock problems (RacingE_Teg)
i think he is talking about power locks.....
i might be wrong.....
Old Oct 25, 2001 | 03:26 PM
E Swift's Avatar
I had the problem about two months ago, took the door apart, and found nothing. My dad sprayed WD-40 into the lock, and it worked fine. Now, today, its giving me problems again. I sprayed it with wd-40 again, and hopefully its working ok again.
I've never heard of holding the handle in the open position, but, I'll try it.
Old Oct 25, 2001 | 03:27 PM
E Swift's Avatar
Default Re: Door lock problems (sweet-teg)
I am talking about the inside lock.
Old Oct 25, 2001 | 03:29 PM
Seedc2's Avatar
had the same problem.. I thought it was my alarm.. but i guess something got caught. Happened one more time after that and its been fine since
Old Oct 25, 2001 | 03:37 PM
Yeah...try doing what I suggested. Does it work?
J.WOLFE~v1.0
Dec 23, 2010 04:23 PM
hs545
Dec 5, 2009 08:51 AM
lead23
Feb 23, 2008 09:12 PM
alacard
16
Jan 25, 2007 09:55 AM
MADEINIRAQ
Aug 25, 2004 07:59 PM
