doing an OBD2b-->OBD1, quick question
Old Aug 7, 2005 | 10:25 AM
LoseRPunKx182's Avatar
Default doing an OBD2b-->OBD1, quick question
i have a DA with a 2000 b18c, it seems like all i need is a conversion harness and the p72 obd1 ecu to do this conversion. can someone verify that?
also in my reading i saw this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote">my 98 gsr (obd2a) to obd1 harness worked great.
make sure if your running a stock intake manifold that the polarity to the vtec solenoid is reversed. </TD></TR></TABLE>
is that a problem? how would i know that its reversed or not?
Old Aug 7, 2005 | 10:31 AM
also i've heard i have to do something with the o2 sensor and tach wire to hook up my autometer tach?
Old Aug 7, 2005 | 12:24 PM
PaChiLa Leader's Avatar
Default Re: (LoseRPunKx182)
if you are using your stock harness from your 92 you can just run it with a p72 OBD1 ECU which plugs and play in your car and problem solved.
problem isn't the year of the engine you r running is the type of the ECU you want to use
hope that helps
Old Aug 7, 2005 | 04:26 PM
i plan to use a p72 obd1. i'm running a p72 obd2b right now
Old Aug 7, 2005 | 04:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">i plan to use a p72 obd1. i'm running a p72 obd2b right now</TD></TR></TABLE>
ok.. if you are already using the OBD2B in your car and plan to run OBD1 then get OBD2B to OBD1 ECU harness that's all.
i have a set made by Skunk2 only used few times.. if you want it make me an offer
laterZ
Old Aug 8, 2005 | 02:06 PM
i just recently brought a obd1 p72 that was socketed for hondata. the guy had the ecu chipped for his turbo but i only have bolt ons. i was wondering if he took the chip out and just keep the socket in would the ecu return to normal operation so that i could just plug and play like stock? or is there a jumper that i have to jump to return it to stock?
Old Aug 8, 2005 | 04:56 PM
98_ssbp
Aug 25, 2010 06:28 AM
nanagsr
Feb 21, 2009 04:16 PM
E.
Apr 21, 2008 08:40 AM
00garrettsi
Jul 19, 2007 05:10 PM
B18 CYA
Jun 1, 2004 11:22 AM
