doesn't turn over
Old Oct 4, 2005 | 10:18 AM
94TegGreen's Avatar
Default doesn't turn over
Ok here's the deal..did a swap from an ls to a gsr..I know i know..don't ask..Anyhow..I'm not gettin any juice to the fuel pump..I have no clue where to start..ANy advice would help..peace
Old Oct 4, 2005 | 10:20 AM
..::91TEG-G2::..'s Avatar
Default Re: doesn't turn over (94TegGreen)
first things first. check your fuses. make sure everything checks out. make sure you're using the right amp fuse. secondly, check your wiring. power wire.. also make sure you have it grounded to a good source. frame, etc places..
if all your wiring is checking out, make sure its not the pump thats burnt out or jammed.
hope this somewhat helps
Old Oct 4, 2005 | 10:22 PM
suzawa94's Avatar
Default Re: doesn't turn over (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">first things first. check your fuses. make sure everything checks out. make sure you're using the right amp fuse. secondly, check your wiring. power wire.. also make sure you have it grounded to a good source. frame, etc places..
hope this somewhat helps</TD></TR></TABLE>
after you have checked ^^, you could suspect the PGM-FI relay. jump #5 and #7 on the relay. if that doesn't work try grounding #3. i can't stress enough that you double and triple check your connections. btw, are you sure you have spark? what about the injectors-are they pulsing? if you got anymore ?'s lemme know. i'm refering to the oem service manual
Jaz760
May 18, 2009 08:21 AM
em1 Ziggy
Audio / Security / Video
Feb 18, 2005 02:43 PM
civcexcoupeblack
May 20, 2003 06:59 AM
importfan85
Dec 30, 2002 11:54 AM
Alexander
13
Oct 10, 2002 10:39 PM
