remote wiring....
Old Feb 16, 2005 | 09:41 PM
em1 Ziggy's Avatar
Default remote wiring....
okay so i got the wiring for my amp.. i want to install it myself .. ig ot the wiring and everything and have the fuses connected with the battery... just need help on the remote wire... i was told that this was just power.... are all remotes colored blue? or do i just connect this wire to the ignition wire?
Old Feb 17, 2005 | 12:12 AM
YellowCVC98EK's Avatar
From: Fairmont is kinda like hell, the only difference, is Fairmont has a polluted river that runs through, the middle of it.
Default Re: remote wiring.... (eK Ziggy)
You can either hook the wire off of the remote lead on the head unit, this way the amp will power up when the head unit is on, or you can wire the remote lead off of an unused fuse in the fuse block under the dash, this way the amp will power on when the ignition is turned on. If wiring under the dash, you can just pull out a fuse, twist the remote lead around one side of the fuse and plug the fuse back in. Most remote leads are blue, it is just simply a way to tell the amp when to turn on.
YellowCVCEK98
Old Feb 17, 2005 | 07:03 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK Ziggy &raquo;</TD></TR><TR><TD CLASS="quote">okay so i got the wiring for my amp.. i want to install it myself .. ig ot the wiring and everything and have the fuses connected with the battery... just need help on the remote wire... i was told that this was just power.... are all remotes colored blue? or do i just connect this wire to the ignition wire?</TD></TR></TABLE>If you are using an aftermarket HU, it will have an amp turn on lead, [blue/white most of the time, may also have blue, power ant. trigger] if you are using the OEM HU you can use the acc. freepin on the fusebox. Do not just pull a fuse and cram the wire in and reinstall fuse not only is that getto, it can damage the fuseholder by spredding the holder out, so when you remove the wire the holder no longer holds the fuse leg tightly, it will lead to intermitant problems, that can be a pain to find, as fuse is not blown. 94
Old Feb 17, 2005 | 07:11 AM
civic_speed99's Avatar
Default Re: remote wiring.... (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Do not just pull a fuse and cram the wire in and reinstall fuse not only is that getto, it can damage the fuseholder by spredding the holder out, so when you remove the wire the holder no longer holds the fuse leg tightly, it will lead to intermitant problems, that can be a pain to find, as fuse is not blown. 94</TD></TR></TABLE>
Good point. Do it the right way once, not the wrong way several times.
Old Feb 18, 2005 | 02:41 PM
H22HondaCRX's Avatar
Modified by H22HondaCRX at 6:28 PM 2/19/2005
Old Feb 18, 2005 | 02:43 PM
I've replied once, Now I'm replying again, I know YellowCVC98EK. If you want we, can box up and send some state record trophies to you, there's alot of them here.
nabs.no.abs
Jan 6, 2009 06:32 PM
Skitals
Audio / Security / Video
18
Sep 16, 2003 08:27 PM
DOHCRX
Aug 10, 2003 04:31 AM
Understeer
Aug 23, 2002 03:04 PM
IdotheSHOCKER
Jun 26, 2002 02:49 PM
