Does compression affect emmisions?
Old Jan 7, 2003 | 04:56 PM
redman223's Avatar
Default Does compression affect emmisions?
I was thinking about getting a mugen headgasket and some skunk2 valves for my car while the head is off, but I am also considering going to the smog ref also to see if I can get my car legalized, but I dont know if my emmisions will be worse with the higher compression? I think it will be up to 10.8 or so (i think the headgasket raises it .5 and the valves .3) please correct me if I am wrong.
Old Jan 8, 2003 | 01:27 AM
Adachi's Avatar
Default Re: Does compression affect emmisions? (redman223)
If you get the right fuel/air ratio you'll be fine.. but that's hard to do w/engine work unless you're running hondata or something like that. Usually when you bump up compression only a little, you'll be okay though.
Old Jan 8, 2003 | 06:24 AM
redman223's Avatar
Default Re: Does compression affect emmisions? (Adachi)
I see, well I guess I'll hold off on it for now though, and work on getting the hondata before any major mods. I just found out it is gonna cost me a little more than i thought to fix the car, so I will have to use the money I was saving for the valves and headgasket.
kelvinchau25
Aug 13, 2006 11:30 PM
redhanyo
19
Apr 17, 2006 08:39 PM
9T6EJ8
May 9, 2004 10:19 PM
PM-Performance
Aug 8, 2003 11:05 AM
Malice
Jul 5, 2002 12:17 PM
