Dizzy. and spark plug problem?
Old Sep 3, 2010 | 11:16 PM
93redDA's Avatar
Icon6 Dizzy. and spark plug problem?
I have a 93 DA and my Dizzy. is throwing a check engine light. The mechanic said its a sensor and the whole Distributor needs to be replaced. He also noticed my cheap spark plug was sticking out. It popped out again today, so I was wondering if its possible for the spark plug to cause the Distributor to throw the code out.
The engine light has been popping on and off for over a month now, so should I be really woried about something going seriously wrong?
Old Sep 4, 2010 | 12:09 AM
honda_90's Avatar
Default Re: Dizzy. and spark plug problem?
waht code is it?
Old Sep 4, 2010 | 12:22 AM
93redDA's Avatar
Code 8, or somewhere close to that cause I'm not sure.
Old Sep 4, 2010 | 12:40 AM
93redDA's Avatar
Whatever the code was its the correct code for a failed sensor in the Distributor.
Old Sep 4, 2010 | 06:23 AM
EHondaJDM's Avatar
What do you mean spark plug "popped out"????
If you have a plug popping out your head you have a lot bigger problems
If its a sensor in the distributor I would assume its the tdc sensor and if that's bad it could cause misfires so I would change it asap
Old Sep 4, 2010 | 07:49 AM
el crapitan's Avatar
lol. i think he meant plug wires. and the tdc code won't be set by that. it would, however, set a misfire code for the corresponding cylinder.
if the wires are popping off the distributor, try spreading the connector(s) slightly so they "clip" into the terminals on the distributor
Old Sep 4, 2010 | 08:26 AM
EHondaJDM's Avatar
^ahh I see
Old Sep 4, 2010 | 10:31 AM
Integra4lyfe069's Avatar
cel code 8 means the tdc sensor is bad. thus cannot be replaced and entire dizzy needs replacing
Old Sep 5, 2010 | 02:01 PM
93redDA's Avatar
Ya it was the plug wire.
Old Sep 5, 2010 | 02:02 PM
93redDA's Avatar
Thanks for the help guys.
Old Sep 5, 2010 | 02:31 PM
EHondaJDM's Avatar
You can replace a tdc sensor in the distributor, its very simple to dissassemble a distributor. But also very simple to **** up so be careful
Jesse_Boyer
12
Dec 24, 2024 02:21 AM
j_moua
Nov 22, 2019 11:09 AM
m3kid
Jun 2, 2012 11:47 AM
jaxx4k
Dec 6, 2004 07:25 PM
jdmsol
Dec 2, 2002 05:57 AM
