DA timing belt replacement
here is some links of the parts you need and how to .This is for a b18c but its the same procedure
https://honda-tech.com/zerothread?id=1404941
https://honda-tech.com/zerothread?id=1605695
http://www.c-speedracing.com/h...t.php
Modified by LLEO245 at 6:08 AM 5/11/2006
timing belts are simple, just use the C-speed racing link, and make sure everything is TDC
i have to do my timing belt today, after you do it once it is easy and just becomes more of a hassle than a pain in the ***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebonyrolla7 »</TD></TR><TR><TD CLASS="quote">ya ive seen that b18c1 write up, but i was under the assumption that you had to take the motor off one of the motor mounts in order to do it...am i wrong</TD></TR></TABLE>
you dont have to take your motor out to do a timing belt just do exactly whats on the site thats how everyone changes it thats the easies way imo.
The Timing belt is really not that hard. You dont need a writeup if you have a Helms on hand. The hardes part for me is getting the tbelt cover off cause our engine bays are built to be worked on by small asian hands =P I have meaty fingers and they dont fit in between the belt cover and the wheel well very well. Took me a good 30 mins just to get that damn cover off...other than that just make sure you have everything TDC and all will go well for you
[QUOTE=Wayne_Curr] our engine bays are built to be worked on by small asian hands =P QUOTE]
this is what i think everytime i have to cram my big hand anywhere to get bolts off lol
tricura
211
Sep 30, 2009 08:52 AM
GQ 05YellowEVO8
Apr 5, 2003 06:03 AM
