D4 Light Flashes
Old Nov 4, 2005 | 04:43 AM
AcuraGirl's Avatar
Default Please help!!!
Hello everyone, I'm new to this site, and was told you guys are the best! Im having a problem with my 98 Integra RS. My check engine light came on about 2 years and my D4 light flashes. When this first happened, I took it to a mechanic who told me it was my vehicle speed sensor, and that there wasn't a rush to get this fixed. My car does not really drive any different then normal, the only thing is I get bad gas mileage which the mechanic said was due to my speed sensor being faulty. Anyhow, I finally took it to Acura to get this sensor fixed and they told me I need a whole new transmission. The codes that they got from my car were..
P0700 - Automatic transmission control
P0715 - Problem in mainshaft speed sensor circuit
P0730 - Problem in shift control system
Now, I understand that those are all tranny problems, but do I really need a whole new transmission? My car just hit 100,000k's, I don't drive it hard, and it doesn't drive any differently. The guy at Acura thought this light just came on, and told me that this was just the beginning of my problems, and said it would only get worse from here, then I told him this light has been on for 2 years and I have not had any problems, and he looked quite surprised. Does this sound normal for a car like mine? Has anyone had this happen to them? I am jsut not sure what to do. I don't really want to spend 3 grand and a new tranny if I don't have to. Please help!
Modified by AcuraGirl at 12:59 PM 11/4/2005
Old Nov 4, 2005 | 06:28 AM
AcuraGirl's Avatar
Default Re: D4 Light Flashes (AcuraGirl)
If it is my transmission, does anyone know where the best place to get another one is?
Old Nov 4, 2005 | 07:31 AM
projectTeG's Avatar
they should just be sensors
Old Nov 4, 2005 | 11:13 AM
AcuraGirl's Avatar
Can anyone help me??
Old Nov 4, 2005 | 01:33 PM
xteg95's Avatar
Default Re: (AcuraGirl)
3k for a stock transmission are you crazy? look in the classifieds and im sure you can find someone parting out their car and would sell cheap... ~500 or so i'd think.
Old Nov 6, 2005 | 07:49 AM
AcuraGirl's Avatar
should i just wait until my tranny dies before i replace it?
Old Nov 6, 2005 | 08:19 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraGirl &raquo;</TD></TR><TR><TD CLASS="quote">should i just wait until my tranny dies before i replace it?</TD></TR></TABLE>
if its throwing codes like those a sensor or something needs to be replaced.
Old Nov 6, 2005 | 09:39 AM
cm zak's Avatar
Check the marketplace, 3k is way to much for a auto transmission, for that you could do a conversion to manual w/ a gsr tranny or even itr..
Old Nov 6, 2005 | 01:57 PM
AcuraGirl's Avatar
Default Re: (cm zak)
I would never pay 3 grand oro a tranny, ill drive my car till it dies, then do a 5 speed tranny in it! I still dont think its my tranny anyways, theres nothing noticable wrong with it.
Old Nov 7, 2005 | 04:58 AM
s2kkid's Avatar
All the codes that you are reciveing, are directly related to your speed sensor.
Lets break this down easily here:
OK- So your speed sensor is shot as you say- this sensor relays voltage to the automatic transmission control unit, the automatic control unit then controls your shift control system to shift the gears at the proper speed smoothly.
You see how One device, can directly reflect two other componets?
You need to just replace the speed sensor. Pick up a good one from a junkyard for chep, and install it. If you were close by id do it for free.
I bet if you repair the speed sensor your other two codes will go away,assuming the hunch i have they are directly related.
Old Nov 7, 2005 | 05:46 AM
AcuraGirl's Avatar
Default Re: (vtecluder97)
That was very helpful, thank you. I will look into finding a speed sensor. Are they hard to put it in? Do I have to take it to a mechanic or is it easy enough for a friend to do?
Old Nov 7, 2005 | 08:23 AM
EG6-SIRII's Avatar
I can do it for you sarah! their pretty simple
ccookie66
Dec 11, 2016 07:01 PM
Bango_Vang01
Jan 19, 2010 03:02 PM
Bad_dude
Jun 5, 2008 01:09 PM
hondaracing1
Oct 23, 2004 11:20 AM
