cuts off
Old Feb 7, 2007 | 12:17 PM
yesSiReK's Avatar
Default cuts off
i was wondering why my car cuts off at 5000 rpms? is it something with the ecu? if so wat can u do to get rid of that?
Old Feb 7, 2007 | 12:21 PM
SuzukaBlueAP2's Avatar
Default Re: cuts off (yesSiReK)
When?
Auto or manual?
In neutral or in gear?
CEL on?
Old Feb 7, 2007 | 12:42 PM
yesSiReK's Avatar
Default Re: cuts off (SuzukaBlueAP2)
watcha mean by when?
manual
gear
CEL?
Rikter's Avatar
He means give us some more information like when does this happen????
CEL = Check Engine Light
-Rik
Old Feb 7, 2007 | 12:58 PM
yesSiReK's Avatar
Default Re: (Rikter)
umm like i said 5000 rpm and no cel thats pretty much it. i thought it was the ecu so i switched the stock one out for a gsr one but it still does the same thing but with the gsr one the cel is on ummm anything else u need to know cuz i don't really know much about any of this so do get mad
Old Feb 7, 2007 | 01:02 PM
Default Re: (yesSiReK)
If the check engine light is on, put the original ECU back in and take it to an auto parts store to read the code.
If I understand you correctly, if you rev the car in neutral, or if you take it to 5K rpm in a gear, it cuts out there, right? When this happens while you drive, does it buck the car back and forth? That would be a fuel cutoff.
I think the CEL has something to do with it.
Old Feb 7, 2007 | 01:37 PM
yesSiReK's Avatar
Default Re: (SuzukaBlueAP2)
should i just take both of the ecu's and have them read the code?
and yea it cuts off at 5k and yup it bucks back and forth so wat is a fuel cutoff? and keep this in mind i'm a noob so don't get mad lol
the cel only came on when i changed the ecu.
i also heard that there is like a chip in the ecu that makes the car cut off at a certain rpm. like it came stock so people don't race and all that crap. is that true? could it be that?
Old Feb 7, 2007 | 02:39 PM
hks369's Avatar
lol no thats not it lol put the original ecu back in tho
Old Feb 7, 2007 | 03:23 PM
yesSiReK's Avatar
Default Re: cuts off (hks369)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hks369 &raquo;</TD></TR><TR><TD CLASS="quote">lol no thats not it lol put the original ecu back in tho</TD></TR></TABLE>
yea it's back in but still cuts off at 5k rpm.
Old Feb 7, 2007 | 03:24 PM
yesSiReK's Avatar
so nobody else knows why? i know you guys know
Old Feb 7, 2007 | 04:12 PM
yesSiReK's Avatar
lalalala
Old Feb 7, 2007 | 06:31 PM
yesSiReK's Avatar
Old Feb 7, 2007 | 07:05 PM
numbnuts22715's Avatar
does it have vtec? if so, check your engine oil... If you're really low, they can really bog and mess up right when, or a little after it hits vtec.
Old Feb 7, 2007 | 07:49 PM
yesSiReK's Avatar
Default Re: (numbnuts22715)
neh no vtec even it's a ls
Old Feb 7, 2007 | 08:10 PM
TB123's Avatar
My GSR is doing the exact same thing right now. When I get to about 5000 rpms It dies and the check engine light comes on. The code on my car is 15 ignition output signal. I am pretty sure that it is the ignition control module. I ordered a new one but it is not here yet. You should find out what code it is and that will help you narrow down the choices of what is wrong. This article tells you how to pull the code and what the codes mean- http://www.team-integra.net/se...ID=34
Old Feb 7, 2007 | 08:15 PM
Default Re: cuts off (TB123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TB123 &raquo;</TD></TR><TR><TD CLASS="quote">My GSR is doing the exact same thing right now. When I get to about 5000 rpms It dies and the check engine light comes on. The code on my car is 15 ignition output signal. I am pretty sure that it is the ignition control module. I ordered a new one but it is not here yet. You should find out what code it is and that will help you narrow down the choices of what is wrong. This article tells you how to pull the code and what the codes mean- http://www.team-integra.net/se...ID=34 </TD></TR></TABLE>
From what I've gathered, he doesnt have a cel...
Only when he swapped to a gsr ecu, which would throw a CEL since his engine doesnt have vtec.
Old Feb 7, 2007 | 08:29 PM
TB123's Avatar
Default Re: cuts off (numbnuts22715)
Ya your right. sorry
Old Feb 7, 2007 | 09:15 PM
yesSiReK's Avatar
neh you shouldn't be sorry just giving ur opinion and it's worth a shot to look at watcha tellin me cuz really don't know wat to do right now but if u guys any more ideas just let me know
Old Feb 8, 2007 | 11:56 AM
yesSiReK's Avatar
any more ideas???
Old Feb 8, 2007 | 12:06 PM
what year is your car again?
You never did state whether or not it was an automatic or manual transmission either.
Old Feb 8, 2007 | 03:38 PM
yesSiReK's Avatar
99 and yea i told u it was a manual right there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yesSiReK &raquo;</TD></TR><TR><TD CLASS="quote">watcha mean by when?
manual
gear
CEL?</TD></TR></TABLE>
Old Feb 9, 2007 | 04:39 PM
yesSiReK's Avatar
-_-
tcontesh
Jul 24, 2006 07:38 PM
blumpfish
Apr 20, 2006 10:28 AM
h8tred
Jul 7, 2003 08:35 PM
TEGME
Jan 27, 2003 03:04 PM
