curious question
10HP is 10HP you should feel a gain. If this is the only reason you are swaping motors then you are going the hard way to gain 10HP.
The compression ratio only really comes into pla when you are looking at building the motor, or if you are going FI. If yo are sticking with NA with the normal I/H/E then the stock honda CR will be just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyBirdJR »</TD></TR><TR><TD CLASS="quote">no no no , jdm only bolts to jdm.....jdm power can only be held by jdm tranny...everybody on ht should know by now</TD></TR></TABLE>
i did a search on here that the jdm tranny is exactly like the USDM tranny except some of the JDM ones have LSD in it. other then that, same gear ratios. so explain your reasoning
EG RICcY
Mar 14, 2005 07:36 PM
vtecjj
May 25, 2004 06:37 PM
AndyD
Jan 6, 2003 07:07 AM
