Crankshaft stuck
#29
Re: (DAmnquickDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAmnquickDA »</TD></TR><TR><TD CLASS="quote">i dont have a hoist but im still trying to find someone with either that or a stand. either way, everyone is right, i need to get the oil pan off.</TD></TR></TABLE>
if you have to put it on a steelie and lay it on its side to get into it, it might be messy though
#31
Re: (DAmnquickDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAmnquickDA »</TD></TR><TR><TD CLASS="quote">Never done that before... ill see what i can do.</TD></TR></TABLE>
lay it on the exhaust side of the engine. just be careful/
#34
Remove the cams, that way all the valves are closed.
I highly recommend pulling the head, especially with a motor you dont know the history and is already giving you problems. My friend purchased a used motor from a junkyard, and found out the hard way, that somehow a nut got in the combustion chamber.
#37
Re: Crankshaft stuck
bump^
yes this is a hella old thread but im having the same issue. instead of starting a new thread and getting told to search for this one.. thread revived.
pulling the motor and oil pan off tomorrow and the head if i must..
backstory...
a few days ago i was driving at 55mph and passing a slow moving vehicle. hit 5k rpms and vtec was hitting. at about 60mph i hear a tick tick tick and it gradually got louder. it all happened so fast that stupid me didnt put the car in neutral and pull over. anyways, tick tick tick snap. engine shut off and crank got stuck. i put it in neutral and coasted to the side of the road. at this point, i tried to crank it once, and no go so i stopped. i tried a rod a long pry bar and 19mm socket and started to torque on the crank and no go so i stopped. curiously, i tried in the opposite direction and the engine went just slightly. so yeah. idk what to do. or what might have caused this.
backstory...
#38
Ops original problem was he was too stupid to take the cams out after taking the timing belt off and was smashing his piston into the open valves.
Your problem may be several things.
Did your timing belt snap? If so, you probably broke valves, and wedged something.
Other issues can be a broken rod. Are there any holes, or loss of oil? Regardless, it sounds like you need to start pulling out that engine
#40
Timing belt is legit and still good, no leaks, no holes. No AC installed so no belt there to check. Alt belt is cherry. It's all internal.
Pulling the vc and oil pan off in a few minutes, I'll take pix and keep you guys posted.
drSquish
10-05-2007 12:32 PM
