cooling fan problem
Old Sep 22, 2001 | 03:32 PM
tonyhondaracing's Avatar
New User
Default cooling fan problem
my cooling fans don't turn on once the engine get hot. My temp guage is going up i have to run the heater on high just so i don't crack the heads. I replace the temp sensor unit and it still is going up. Can someone tell me what wrong
Old Sep 22, 2001 | 04:15 PM
vti-R's Avatar
Default Re: cooling fan problem (tonyhondaracing)
i have the same problem my fan diesnt go on when the engine is hot but the temp gauge never go fast 1/4 mark even under hard and long driving. dont know whats wrong with it....
Old Sep 22, 2001 | 07:21 PM
JM Performance's Avatar
Default Re: cooling fan problem (vti-R)
check the fuse.......just an idea
Old Sep 22, 2001 | 07:28 PM
Prelussion's Avatar
Default Re: cooling fan problem (00SilverLS)
check the two relays under your radiator, and there's some electrical stuff in your dash behind your glove box. If everything checks out w/ the thermostat it's more than likely your relays, Honda has problems with their relays.
Old Sep 23, 2001 | 09:36 AM
New User
Default Re: cooling fan problem (Prelussion)
were is the fuse located and what number is it
nelson0616
Nov 16, 2016 11:36 AM
aasaa666
May 31, 2010 07:15 AM
Donhonda84
Apr 4, 2007 08:36 PM
thundergrey94ls
Jun 26, 2005 04:49 PM
celica26
Dec 29, 2004 08:40 PM
