Constant check engine light
Well if you get a CEL it means something is wrong and merely resetting doesn't do you any good. Here is a link to how to read you CEL and see what code you are throwing up.
https://honda-tech.com/zerothread?id=978933
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billyhoe »</TD></TR><TR><TD CLASS="quote">its code 1 the primary oxygen sensor </TD></TR></TABLE>
Ok, did you try replacing the o2 sensor, then resetting the ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billyhoe »</TD></TR><TR><TD CLASS="quote">one long blink is code 1 or code 10?</TD></TR></TABLE>
1 Long blink should be 10. 1 short blink is 1. LONG flashes determine the TENS digit by the number of times it flashes, and SHORT flashes determine the ONES digit by the number of times it flashes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iixerOii »</TD></TR><TR><TD CLASS="quote">
exactly, although o2 sensor would cause a constant check light if its bad
Ramireg
Feb 9, 2007 07:15 AM
drumminforev
25
Nov 11, 2006 09:19 PM
