constant backfiring
Old Dec 8, 2004 | 07:49 PM
Dee A Nine's Avatar
Default constant backfiring
damn it. my DA is coughing (suffering from constant backfire)... and when it does, my check engine light goes on... i feel like i got it from having custom 2.5 piping... and it's not stainless steel... i'm gonna try and change the piping to stainless steel and see if this problem occurs.. but has this ever happen to anyone else? what'd you do to stop it (if you did have it) ??
Old Dec 8, 2004 | 08:03 PM
C4wrx's Avatar
Default Re: constant backfiring (Dee A Nine)
Check your vacum at idle it is not steady try to do a valve adjust on it.
Old Dec 8, 2004 | 08:07 PM
ian.'s Avatar
Default Re: constant backfiring (C4wrx)
i had the same exact thing but it went away after a while to the piont where it barely did it
Old Dec 8, 2004 | 08:14 PM
Dee A Nine's Avatar
valve adjustment in the engine you mean?
Old Dec 8, 2004 | 08:29 PM
C4wrx's Avatar
yes. when is the last time you did a tune up on it?
Old Dec 15, 2004 | 09:34 PM
Dee A Nine's Avatar
****... uhh... about 3 months... i've been looking to changing the spark plugs sometime soon... but since then, i got new piping with a resonator... 2.25... and the backfire has gone down a bit... but.... now my idle is hyperventilating.... wassup with that?
Old Dec 15, 2004 | 10:21 PM
cnydc2's Avatar
Dude, That definatly sounds like a vac leak. Is the idle loping reallt bad or only 200-500 rpms?
Old Dec 16, 2004 | 07:43 AM
orangeturbogsr94's Avatar
what kind of ecu do you have? I know that if you have standalone it might not be tuned right or running really rich.
Old Dec 17, 2004 | 01:11 PM
Dee A Nine's Avatar
Default Re: constant backfiring (orangeturbogsr94)
the idling goes from 500-1500 and does that every time i drive... and i think i might not be running rich bkuz i'm only putting 89... gas is still expensive... and it still gets me by... but maybe thats it... i'll get 91 next time i hit the 76 gas station.
Old Dec 17, 2004 | 01:12 PM
Dee A Nine's Avatar
and it's a stock ecu by the way
Old Dec 17, 2004 | 02:37 PM
xprohx's Avatar
I think too much
Check the code and go from there. I don't believe going from mild steel to a stainless steel exhaust will resolve your problem.
Old Dec 17, 2004 | 04:58 PM
92CIVICCX's Avatar
Default Re: constant backfiring (xprohx)
ive got the same prob on my teg..... i figured out (but been to lazy to fix it) thata there is either a vac leak or my timing is all screwed up... ubt yeah it lopes from like 500 to 200 them jumps up real quick and goes back to idle...
Old Dec 17, 2004 | 06:28 PM
DavidT or VajT's Avatar
Default Re: constant backfiring (92CIVICCX)
Backfiring may be from your spark plug wires, or spark plugs. Maybe the person who installed the wires last put #2 wire into the #3 spark plug, or the other way around. Check the wires and your plugs. Hope everything works out good...
Old Dec 18, 2004 | 06:27 AM
FR-MOB: ThE bEe GuY's Avatar
hmm...To me it sounds like a timing problem. Either its too advanced, too retarded, or the cams are off a tooth or something. Have access to a timing light? wouldnt hurt to check that
v1crattlehead
May 30, 2008 07:08 PM
martyball619
Apr 27, 2008 11:58 AM
phanatic
Jul 24, 2006 02:13 AM
Pfieff
Dec 1, 2003 08:00 AM
wessieball
Mar 25, 2002 05:18 PM
