Compression Test / Main Relay Question
Old Jan 6, 2021 | 08:17 PM
danielbcramer's Avatar
Default Compression Test / Main Relay Question
I’m going to be running a compression test on my 00 GSR soon. I have a kill switch wired to the ground wires on my main relay. Is flipping the switch to off (disabling main relay) sufficient to stop fuel and spark in order to run a compression test? Or should I be disabling more?
Old Jan 11, 2021 | 09:10 PM
Default Re: Compression Test / Main Relay Question
Bump
Old Jan 14, 2021 | 03:42 AM
Bottlefedz28's Avatar
Loved
You’ll already have the spark plug boots off and plugs out so all you need to do is kill the fuel pump, st pull the fuse
Wildwilly3
Mar 5, 2019 04:41 PM
FullOutPwr
Jul 17, 2014 04:46 PM
street_ride14
Jun 20, 2007 04:34 AM
xhimurakenshinx
Mar 29, 2005 08:12 PM
