Compression test help
Old Sep 23, 2003 | 01:39 PM
Nighthawk GS-R's Avatar
New User
Default Compression test help
OK Im going to do this in a hour or so and i have the compression test tool. What I need to know is how exactly you do it and what the stock numbers should be per cylinder with roughly 40,000 miles. Any info would be greatly appreciated.
Old Sep 23, 2003 | 01:59 PM
New User
Default Re: Compression test help (Nighthawk GS-R)
anyone?
Old Sep 23, 2003 | 02:10 PM
fuck honda-tech's Avatar
im not 2 sure but i know that all of the numbers should be around the same not like 160 , 55 good luck
Old Sep 23, 2003 | 02:25 PM
Chemicalviper's Avatar
200+ is good 44 k u should be around there - there will always be 10 +/- off. so if its 220 210 220 215 ur fine - not 220 120 200 200 heheh
Old Sep 23, 2003 | 02:27 PM
o i was gonna tell ya how to do it - take out all plug wires ( MAKE SURE engine is warmed up before turning off ) please search for this next time too - its been covered for sure - put tester in one cylinder - clutch in, gas full throttle - start it - let it crank a few times, only takes a few seconds, not even, the other person should be looking at the tester shows
Old Sep 23, 2003 | 03:45 PM
VTECorona's Avatar
Default Re: (Chemicalviper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper &raquo;</TD></TR><TR><TD CLASS="quote">o i was gonna tell ya how to do it - take out all plug wires ( MAKE SURE engine is warmed up before turning off ) please search for this next time too - its been covered for sure - put tester in one cylinder - clutch in, gas full throttle - start it - let it crank a few times, only takes a few seconds, not even, the other person should be looking at the tester shows</TD></TR></TABLE>
Partially correct, except his injectors and fuel pump will be flooding his motor and making a mess.
Warm up the car to normal operating temp, pull out the FI relay that is to the left of your fuses. You will probably have to remove the 10mm bolt that is holding it in because it is impossible to get it out the way that it is mounted. Once that is out remove your plugs and put the guage in one of your spark plug holes. Push the gas pedal all the way in, clutch all the way in and start cranking the motor. When you or your friend see's the PSI stop climbing then you're done. Repeat on other 3 cylinders and record results.
Old Sep 23, 2003 | 04:37 PM
New User
Default Re: (VTECorona)
yeah thanks guys..I just did it.
Cylinders 1-3 read 215 and cylinder 4 read 208
Old Sep 23, 2003 | 05:00 PM
VTECorona's Avatar
Default Re: (Nighthawk GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk GS-R &raquo;</TD></TR><TR><TD CLASS="quote">yeah thanks guys..I just did it.
Cylinders 1-3 read 215 and cylinder 4 read 208</TD></TR></TABLE>
nice
did u do 4 cranks or did u go til it stopped rising?
Old Sep 23, 2003 | 05:08 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
can't get much better than that
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
Honda_Cribb_GS-R
25
Sep 10, 2008 04:05 PM
infamouskillas
Jun 9, 2008 09:26 PM
projektCRX
Apr 22, 2004 12:18 PM
Nate B
Jun 17, 2003 09:56 PM
