Compression Ratio
Old Oct 25, 2005 | 04:28 PM
whitegsrhatch's Avatar
Default Compression Ratio
i have 94 gs-r w/ je pistons, eagle h-beam rods, stock sleeves, pretty much a brand new bottom end, on the head 3 angle valve job, new valves, lifters, everything is rebuilt with 10.4-1 to 10.6-1 compression ratio (within the two) would this be too high to boost? around 7-8 psi? if tuned w/ hondata and a diffrent fuel pump?
Old Oct 25, 2005 | 04:49 PM
nickG's Avatar
Default Re: Compression Ratio (whitegsrhatch)
find someone who can tune it..and i dont see why you wouldnt be able to...
some will say its too high, but youll just be making more power on less boost....
but i dont think it is safe to just boost and go...contact someone who can tune and talk w/ them about it..
i dont think many ppl on H-T have actual experience w/ higher compression and boost...almost everyone here will say "thats way too high..lower is better"
check the FI forum too...
Old Oct 26, 2005 | 05:56 AM
Default Re: Compression Ratio (nickG)
im using hondata s200 w/ boost and a tune by jeff evans.
Old Oct 26, 2005 | 02:02 PM
anyone else??
RooskiGSR
Feb 28, 2005 04:23 PM
7rrivera7
Apr 20, 2004 03:46 AM
7rrivera7
Oct 23, 2002 06:58 AM
thinkbrianthink bu
Oct 13, 2002 10:47 AM
