Compression Check Discussion
Old Jul 30, 2001 | 08:23 AM
Evil DOHC's Avatar
Default Compression Check Discussion
There are many ways of doing a compression check on GSR's. I was wondering what would be some of your favorite LOL. Seriously what is the proper way of doing a compression check on a gsr motor as well as PSI numbers.
Thanks in advance,
EVIL
Old Jul 30, 2001 | 08:28 AM
TypeC's Avatar
Default Re: Compression Check Discussion (Evil GS-R)
Evil,
it's pretty simple. take out the spark plugs, put the gauge in the SP hole, remove ecu fuse (so you won't have fuel in the cylinders), floor the gas pedal to open the TB, crank the motor over about 7 times. 180+ psi is good, 200+ psi is great (mine were all btwn 200-215). HTH, -C
Old Jul 30, 2001 | 09:10 AM
GSRacer's Avatar
New User
Default Re: Compression Check Discussion (TypeC)
i can't believe evil asked this question!!!!! even i knew that one. eh eh eh eh eh eh eh eh eh eh eh eh eh eh
Old Jul 30, 2001 | 09:28 AM
Evil DOHC's Avatar
Default Re: Compression Check Discussion (GSRacer)
I did my compression check without pulling the fuel pump or the ecu fuse. I doubt it gave me higher compression numbers than usual, but I will have to check again in the future.
EVIL
Old Jul 30, 2001 | 10:00 AM
dustin's Avatar
Actually, having the ECU inject fuel can cause lower compression numbers, because all the puddling fuel destroys the oil seal w/ the rings. When I compression tested with the ECU fuse in, I actually got LOWER numbers than without it.
Dustin
Old Jul 30, 2001 | 10:07 AM
TypeC's Avatar
Default Re: Compression Check Discussion (dustin)
that's wierd, because when you think about it, the fuel in the cylinders would decrease the chamber volume and increase the CR. It'd be cool to do a controlled test to actually find out exact how much it changed in either direction. -C
Old Jul 30, 2001 | 10:09 AM
Evil DOHC's Avatar
Well either way my compression numbers are higher than 200, so I am a happy camper.
EVIL
Old Jul 30, 2001 | 10:46 AM
Mr. Choi's Avatar
New User
you should make sure that your engine is at the proper opertaion tempature when doin a compression check.
Old Jul 30, 2001 | 11:10 AM
Evil DOHC's Avatar
Default Re: Compression Check Discussion (Chois i-VTEC)
Yes I was aware of that. LOL
EVIL
Old Jul 30, 2001 | 01:00 PM
Rory Breaker's Avatar
Oops...I just did a check without pulling the ECU or hitting the gas...
It was a spur of the moment thing...I need to do my homework
My #s were kind of low...would that be the reason?
Old Jul 30, 2001 | 01:09 PM
Evil DOHC's Avatar
Default Re: Compression Check Discussion (newgsrdriver)
I still got high numbers, by not pulling the fuse.
Your car is a 95, it might be time for some ctr pistons
EVIL
Old Jul 30, 2001 | 01:21 PM
quikrpm'z's Avatar
what brand tester is everyone using, i have a craftsmen.
Old Jul 30, 2001 | 01:23 PM
dustin's Avatar
Default Re: Compression Check Discussion (quikrpm1)
The fuel does not really stay in the cylinders for all that long... it leaves the exhaust valves. I have tested many times and I always get lower numbers with the fuse in.
Dustin
TypeC's Avatar
hell yeah, that's why. If you don't press the gas pedal, the air has to squeeze around the TB. Your number will be way low (I did that too a long time ago on my other Teg).
Old Jul 30, 2001 | 02:08 PM
WOTTEG's Avatar
I don't have my Helm's here at the office, how do you turn the crank? Do you need a special tool? Or Just jack up the car and turn the wheels. I heard 5 turns at teh Crank was fine. As long as it is consistant for each cylinder.
[Modified by WOTTEG, 3:09 PM 7/30/2001]
Old Jul 31, 2001 | 02:23 AM
IgniteTeg's Avatar
Okay anybody help me out here I have no clue what this really does?? How do you crank the motor or whatever your talkin about?? I gotta learn somehow Also where is the SP hole? Are you suppose to do this with the engine on or off and whats the purpose of doin this? Thanks for the help guyz or gurlz.
[Modified by Vietracer, 3:28 AM 7/31/2001]
Old Jul 31, 2001 | 07:09 AM
WOTTEG's Avatar
Default Re: Compression Check Discussion (Vietracer)
You can buy a compression test kit. Comes with a gauge and a couple of fittings on the end of a hose. The hose goes in place of one of your spark plugs.
Compression How-To
[Modified by WOTTEG, 8:12 AM 7/31/2001]
Old Jul 31, 2001 | 08:34 AM
TypeC's Avatar
Um, the spark plugs holes are the holes where the spark plug wires going into. on the GSR, it's under the grey spark plug wires. The compression test tells you how well your motor is sealing on the compression stroke which can tell you if your rings aren't sealing or a valve is bent. No, you can't do this with the motor on for obvious reasons (won't start with no plugs).
WOTTEG:
when I said crank the motor, I meant using the key and ignition. Do it 7 times (ecu fuse removed). HTH, -C
Old Aug 2, 2001 | 02:22 AM
IgniteTeg's Avatar
Thanks for the help so. If i'm goin to do taht compression check i have to turn the igition key to the on position or all the way and turn it off and keep doin this for 7 times? This only helps if you go FI or all motor right???
NFM_Dm
Apr 9, 2010 04:39 PM
one bad dx
Jan 4, 2007 09:55 AM
17GSR17
Jun 19, 2004 08:14 AM
insomniac791
Jan 7, 2003 08:01 PM
