Compression Test / Leak Down Test
Old Feb 12, 2007 | 06:09 AM
godnf8's Avatar
Default Compression Test / Leak Down Test
What are the typical numbers on a compression test on a 01'ITR
Also if the compression test shows good numbers across the board does that mean my Piston rings are ok or will I need to run a leak down test as well.
I'm just really paranoid after having the rings go bad on my '00 Si and want to make sure all is well on my new R
Compression test Numbers I got
Cyl#1 205 Cyl#205 Cyl#3 210 Cyl#4 210
Old Feb 12, 2007 | 06:16 AM
BABY NSX's Avatar
Default Re: Compression Test / Leak Down Test (godnf8)
Your compression numbers look great.
The actual number varies depending on the gauge you are using. My stock engine last measured 180 across the board before the rebuild. It now measures ~280 with the same gauge.
What you are mainly interested in seeing is good consistent numbers which is what you have.
Old Feb 12, 2007 | 06:24 AM
walker111's Avatar
Default Re: Compression Test / Leak Down Test (BABY NSX)
A friend of mine at Pohanka did the checks on that car. He said everything looked great
My bust I missed your call yesterday, was getting my car towed.
Old Feb 12, 2007 | 06:38 AM
Doostur's Avatar
My Compression is 225 225 224 225. I think the span is 180-240. Each number being within 0-15 of each other or id start to worry.
Old Feb 12, 2007 | 07:09 AM
godnf8's Avatar
Yeah, I had the honda dealership do the test, just don't want to have same problem I had in my Si, being paranoid I guess -_-
Old Feb 12, 2007 | 07:33 AM
crxgator's Avatar
you want to be sure of everything do a leakdown...
my compression was as follows
208 210 210 212
leakdown
0 12 44 25
76 camaro car
Apr 20, 2017 04:47 AM
humboldt_skim
May 31, 2008 08:18 AM
Got_soy
28
Aug 8, 2005 12:49 PM
quaker
Jan 5, 2005 05:33 AM
