Compatible distributors for d16a1?
Old Jul 15, 2014 | 01:27 PM
bairdandrew77's Avatar
Default Compatible distributors for d16a1?
My distributor tested bad on my DOHC d16a1 and needs to be replaced. Does anyone know if any other obd0 ones will work as a replacement for the d16a1/ZC's td03u? I have a td01u, I believe it might have come off my CRX when it was still DPFI. With my luck it won't work, but I'm going to try anyways when I have more free time unless someone can give me a solid answer.
Getting another td03u wouldn't be a big deal, but they're not exactly common in junkyards like most others. And I'd prefer to avoid buying a remaned one from anywhere since they always fail. The one I have is apparently remaned and I didn't notice that when buying the car.
Old Jul 16, 2014 | 08:49 AM
tamboo's Avatar
10 Year Member
Default Re: Compatible distributors for d16a1?
test and replace coil and/or icm with a decent brand from rockauto/ebay.
united electric and airtex wells are good choices. carry spares if you can afford
them.
http://www.team-integra.net/forum/bl...eshooting.html
Old Jul 17, 2014 | 01:57 PM
Thanks, very informative link. However, my car starts up perfectly. The ICM is good. I'm getting a code 4 for a crank sensor and followed Alldata word for word and the CKP in the distributor tested a bit out of specs. Absolutely everything else tested good. From what I understand you can't simply replace the sensor, but have to replace the whole distributor. I wish it was something like an ICM or coil, I can swap those out for free with my spare parts!
.nate
Sep 10, 2013 01:00 PM
natedawg500
Jul 5, 2011 11:25 PM
zx1216
Oct 1, 2008 05:29 PM
busychild
Dec 3, 2004 03:12 PM
gsr98vtec
Jan 7, 2002 11:13 AM
