cold start up problems
Old May 13, 2008 | 07:26 AM
civiclxb16a's Avatar
Default cold start up problems
Ok guys my wifes car has a little problem that is getting on my nerve. It just started happening about 5 days ago and I am a bit lost. My wife has a 94 integra ls. its all stock but the filter. (k and n) so the other day my wife went to go start her car and i heard it take a few turns more then normal to start up. First thing that came to my mind was her timing is off. Now her timing belt set (belt water pump tensionor) was replaced at 100k she is now at 132k. she also has a brand new dizzy from DK. i set the timing she might be around 5k on that. I double checked the timing and its dead on right on the red mark on her crank pulley. So i let her car warm up and checked it again dead on. i checked her idle 750 rpms. So i asked her "when did this start happening?" she replied a few days ago. so i thought about it and a few days ago she let her fuel get really low, i have no clue why but she did. After thinking about it more she has a really bad habbit of letting it get low. So i am wondering if its her fuel pump not putting enough fuel pressure for start up. Now here is why i think that. She starts her car and it will take a while to start. she can drive it for 30 mins or so and then turn off the car and then start it up again and its perfect. but if the car sits for say 8 to 10+ hours it will start like i stated. So all my money is on the fuel pump what do you guys think?
Old May 13, 2008 | 08:37 AM
infamouskillas's Avatar
Default Re: cold start up problems (civiclxb16a)
if it is what you say about the fuel pump.... the thing i would try doing is disconnecting the negative terminal from your battery, and reconnecting it
this way your ecu will obviously reset...and adapt to the new settings...
in other words:
- fill your tank
- reset your ecu
- let ecu adapt to settings
think of it this way:
if you reset your ecu, and drive the hell out of your car...it will increase throttle response and acceleration....
yeah i kno this seems whacked but i mean its worth a shot...and its not hard at all so...good luck with the problem
Jdbdkid93
15
Jan 25, 2021 05:20 PM
Dangousity
Feb 10, 2010 03:58 AM
Tarlacon
Nov 9, 2008 10:40 PM
nighttrain33
Mar 23, 2008 01:38 PM
Will_H
Apr 18, 2004 03:49 AM
