cold start idle.
Old Nov 16, 2001 | 08:11 PM
quikrpm'z's Avatar
Default cold start idle.
When i start my car in the mornings the idle will rise to 1600-1700 and start making a weird buzzing noise. A normal startup idle i think is at 1500 and at that point it sounds normal. Can anyone shed some light as to why my car does this? tia.
Old Nov 16, 2001 | 08:34 PM
gsxr's Avatar
Default Re: cold start idle. (quikrpm1)
the buzzing noise might be the abs pressurizing...
Old Nov 16, 2001 | 09:20 PM
quikrpm'z's Avatar
Default Re: cold start idle. (gsxr)
I dont have abs.
Old Nov 16, 2001 | 10:12 PM
InfamousRS's Avatar
I don't have abs either, I don't have the buzz though. Is it normal to cold idle at 2000 rpm? My car does for about 5 minutes then goes down.
Old Nov 17, 2001 | 12:16 AM
Phat Corolla's Avatar
New User
Default Re: cold start idle. (BLK94RS)
Your sig says you have a turbo, correct?? I'd assume that it is some turbo component. You might want to check some stuff. I haven't really dealt with turbos, so I don't have anything specific to suggest. Good Luck.
Old Nov 17, 2001 | 12:36 AM
Calavera's Avatar
Default Re: cold start idle. (Phat GS-R)
Your idle should drop after 2~3 minutes to 750~800 rpm. But then again, I live in SoCal, so I have no idea what effect the weather would have on the idle.
Anyways, I was told that idle should drop after 2~3 min max to 750rpm or so from the dealership.
Old Nov 17, 2001 | 05:41 AM
SuperMan19's Avatar
New User
mine buzzes sometimes for a couple secs... but I don't think anything's wrong.. it runs fine.
Old Nov 17, 2001 | 06:15 AM
project_DC2's Avatar
Default Re: cold start idle. (MyKarsNameIsMichelle)
mine buzz's too! Its my heat shields ( crack )! Might want to check for that! IF that helps! If not, then..............right now cant help you! Good Luck
Old Nov 17, 2001 | 08:06 AM
Anthony K's Avatar
New User
An initial 1600-1700 cold idle should be normal. After a minute or two, it should begin dropping. The buzzing is probably just a component rubbing or something. Or maybe you might wanna look over your Drag inline fuel pump which is usually kinda loud.
efyou
Apr 18, 2007 06:00 PM
tylerdurden
Apr 11, 2003 05:53 PM
TegGSR96
Oct 1, 2002 06:29 PM
