code p0107 help!!!
Old Jul 24, 2014 | 08:03 PM
jdmacuraITR's Avatar
Default code p0107 help!!!
I have a 1998 Acura integra gsr.
It has a skunk2 manifold, blox throttle body and i replace the map sensor,tps, cap, rotor and i don't know if there a leak.... code still wont go away
Please help thank for readings
Old Jul 25, 2014 | 11:58 AM
tamboo's Avatar
10 Year Member
Default Re: code p0107 help!!!
http://engine-codes.com/p0107_honda.html
Old Jul 25, 2014 | 02:20 PM
wunfstgsr's Avatar
Loved
Community Favorite
make sure you diddnt switch the map and tps plugs.
or maybe your map sensor is bad.
Old Jul 26, 2014 | 06:14 PM
I made sure and the map sensor is a week old but i unplug the map sensor and plug it back in nothing happen so is there sonething wrong with my harness
Old Jul 26, 2014 | 07:22 PM
hydell3's Avatar
There's an o-ring under the map sensor if its not there that'll cause ur problem.
Old Jul 28, 2014 | 06:06 AM
I bought new o ring gasket and clear the code and it still pop up
FSS13foxtrot
Jan 20, 2008 06:23 AM
92ehatch
16
Feb 19, 2007 11:41 PM
vtec25
Oct 6, 2004 08:26 PM
MugenizedR
Nov 1, 2003 03:43 PM
