code 4
Old Dec 17, 2006 | 10:12 PM
95_red_dc's Avatar
Default code 4
I have a b18b in my crx obd1 conversion and some times when driving code 4 comes on and then when I shut it off it does not come on what would the cause of that?
Old Dec 17, 2006 | 10:55 PM
95_red_dc's Avatar
Default Re: code 4 (ls_swaped_crx)
would code 4 throw your timeing off?
Old Dec 18, 2006 | 03:58 AM
god.loves.ugly
Guest
Posts: n/a
crank position sensor. I think when it throws this code it limits the engine does it bog out at like 3k?
Old Dec 18, 2006 | 02:29 PM
95_red_dc's Avatar
Default Re: code 4 (god.loves.ugly)
The car feels some what slow all around, but its weird it come on every once in a while and I will shut it off start it back up and it will be off. What should I check or do about it?
Old Dec 18, 2006 | 04:46 PM
god.loves.ugly
Guest
Posts: n/a
do a search on here I would check all the wiring first. make sure somethings not loose, then go from there the CPS is the distributor if i remember correctly that might be bad.
Old Dec 20, 2006 | 07:40 AM
95_red_dc's Avatar
I am about to check the wireing on the dizzy, but my check engine ligt comes on more often on now and stays on sometime to.
Old Dec 21, 2006 | 04:35 PM
95_red_dc's Avatar
Just today My car started to bog really bad sometimes below 3k rpms but no check engine light is on! Today I check my compression on the b18b it came out at 180 180 175 175 thats not bad right as long as it is not to far apart but some b series motors I have seen it up to 2 somthing for the compression why is that?
skaternak
Oct 29, 2008 01:40 PM
sexyblack93lude
Oct 24, 2005 04:08 PM
Leets
Mar 25, 2002 08:41 PM
