Code 3 help
Old May 7, 2004 | 10:07 AM
TurboTeG4's Avatar
Default Code 3 help
What do I do if I get 3 MAP - manifold absolute pressure sensor , it blinks 3 times stops and repeats. I chked my sensors it seems good?ANything I should do>?
Old May 7, 2004 | 10:09 AM
frenchy's Avatar
Default Re: Code 3 help (TurboTeG4)
how did you check the sensor?
Old May 7, 2004 | 10:12 AM
Audi A4's Avatar
Default Re: Code 3 help (frenchy)
Are u using a missing link?
Old May 7, 2004 | 11:53 AM
TurboTeG4's Avatar
Default Re: Code 3 help (DRAG lll INTEGRA)
No missing link, didnt really chk the sensors, anything to do with the vafc pressure wire?? I found out that the guy who hooked up my vafc didnt have the pressure wire connected so I connected it(that was a while ago)
Old May 7, 2004 | 11:56 AM
Audi A4's Avatar
so ur running a turbo with out a missing link?
Old May 7, 2004 | 12:02 PM
TurboTeG4's Avatar
Turbos not on right now, got another engine being built in cali, I dont plan on running a missing link when the turbo goes bak in. Just vafc, pump, injectors??
Now its stock with i/h/e, msds
Old May 7, 2004 | 12:39 PM
frenchy's Avatar
have you reset the ecu since you hooked up the vafc right?
Old May 7, 2004 | 01:39 PM
TurboTeG4's Avatar
no how do i do it, sinch I hooked up the pressure wire I had not reset anything
Old May 7, 2004 | 01:45 PM
Audi A4's Avatar
u do it with the vtec controller.. ur manual should tell u
Old May 7, 2004 | 01:52 PM
frenchy's Avatar
you can either a: - unhook your battery for a while(ive heard 5-10 mins) or b: the right way per helms take out the 7.5 fuse in the under the hood for 10-15 sec. - number 32 - if you still have the fuse placement sticker on your cover - the radio should turn off as well if you pull the right one - just make sure if you still have the stock radio that you have the code
Old May 7, 2004 | 01:53 PM
frenchy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">u do it with the vtec controller.. ur manual should tell u</TD></TR></TABLE>you can reset the ecu w/ a vafc?
Old May 7, 2004 | 01:54 PM
Audi A4's Avatar
oh my bad im thinking he needs to reset the vafc.. aka initilize it
Old Jun 6, 2004 | 12:46 AM
TurboTeG4's Avatar
Well I reset the ecu and still throws code, and today when I red lined 1st and went to redline 2nd the chk engine light came on and I lost throttle response. Any ideas on what I should change?
Old Jun 6, 2004 | 01:42 AM
Sack Master's Avatar
Start by borrowing a map sensor from a friend to see if thats the problem.
Old Jun 6, 2004 | 02:44 PM
polyphony_digital's Avatar
Default Re: Code 3 help (Sack Master)
I have this same problem. I even replaced the map sensor and it still does it. Runs real rich. Still looking into this myself. ;_;
Modified by polyphony_digital at 3:28 PM 6/7/2004
Old Jun 19, 2004 | 11:43 AM
TurboTeG4's Avatar
Default Re: Code 3 help (polyphony_digital)
Ok , my problem seems to come on intermitent cause it only comes on when you drive the car for a while then when it comes on the car get sluggish. Helms manual says interminent problem chk wiring, well I resoldered everyting so I skip that part and check the voltages instead. Yellow/White & Chassis Ground-5 Volts
Yellow/White & Grn/White-4.98 Volts, White/Yello & Grn/White-.049 Volts
Any ideas what to do, should I just change the map sensor? This has been a problem since I got the car
Old Jun 19, 2004 | 02:36 PM
TurboTeG4's Avatar
Just bought a 2000 civic map sensor the local shop charged me 40.00 I gotta c if it works. It works alright no more codes yeeeeha
Modified by TurboTeG4 at 5:00 AM 6/20/2004
Old Jun 19, 2004 | 02:45 PM
It would be a wise investment to get a missing link also(probably the easiest way and it's reliable). Running check valves to your map sensor won't stop it from blowing the diaphragm out or getting whach readings.
Old Jun 24, 2004 | 09:01 PM
TurboTeG4's Avatar
**** me not, I got a code 3 again today It ran good the last time, I took it for some good test runs on the mountain. But today I went back up there and did a wot vafc at 69%throttle and the engine just bogged all of a sudden and you can smell the exhaust change also.
I already changed the sensors, does the sensor wires go straight to the ecu? Meaning that I could possibly run new wires straight to the ecu and see what happens.
Old Jun 25, 2004 | 09:33 AM
TurboTeG4's Avatar
Old Jun 26, 2004 | 09:41 AM
TurboTeG4's Avatar
Arrghh, someone mentioned that I should take out my vafc?
Old Jun 29, 2004 | 10:04 PM
TurboTeG4's Avatar
spotscivic
Dec 14, 2007 10:43 PM
HumanH23
Aug 5, 2005 08:27 PM
MickeeFREE
Apr 14, 2005 09:36 PM
EvilIntegrationLS
Aug 5, 2004 12:13 PM
0 0 0
Jan 14, 2004 09:03 PM
