code 20; elecronic load detector
Old Feb 12, 2006 | 01:33 PM
loudassVTEC's Avatar
Default code 20; elecronic load detector
I started my car up this afternoon, and all the sudden the check engine light came on 5 seconds later. I drove home, and checked the codes. Two long blinks...four second pause...7 short blinks...four second pause...repeats. So I'm guessing that means codes 7, and 20, since there are no code 27's. Code 7 is TPS, and code 20 is ELD. Does anyone know how I'd fix code 20?? Or even if there is actually a sensor to replace?? I know I need a TPS. Does anyone know if replacing the tps would clear both codes??
Old Feb 12, 2006 | 01:42 PM
Default Re: code 20; elecronic load detector (loudassVTEC)
Forgot to mention...I'm running a 1st gen b16 converted to obd-1 in a '90 DA with a p28 ecu chipped and running Uberdata with a stock 2nd gen b16 map, with extended rev-limit to 8300, and VTEC engagment at 5500. Running I/AEBS manifold/header/exhaust
Old Feb 12, 2006 | 03:50 PM
bump
tavo.760
Nov 12, 2013 12:32 AM
Mr.Death
Apr 30, 2010 05:51 PM
EKtypeRhaTcH
Jan 13, 2005 04:53 AM
gsr2envy
Nov 7, 2004 03:32 PM
RRRex
May 7, 2003 05:06 PM
