Fuel Injectors Code 16....Help!!
Old Sep 17, 2003 | 04:35 PM
turboxsi's Avatar
Default Fuel Injectors Code 16....Help!!
I just changed my fuel rail to a stock GS-R one on a B16a. After that everything was fine until the next day im in 3rd gear at 7k and i get a Code 16 and my ecu goes to Limp mode, like i hit my rev limiter. Wiring has been the same for years so no problem there. Could it just be i need new injectors or a main relay?? Has anyone ever exprienced this, please help!!
And if it matters the car starts right up everytime and is able to go to 8k and others it cuts me off with the code 16. Thank you in advance for any help!!
Old Sep 17, 2003 | 06:00 PM
zigs's Avatar
Default Re: Fuel Injectors Code 16....Help!! (turboxsi)
Reset your ecu. It could be bad injectors or a loose wire double check and make sure all the clip are secure but more than likely you just need to reset the ecu.
nineohnine
Jun 16, 2009 07:28 PM
H22Ej1
Jan 23, 2009 10:35 AM
crxforum
Jun 12, 2004 06:07 PM
delux247
Jan 28, 2004 11:48 AM
turboxsi
Sep 17, 2003 05:22 PM
