Code 16 what to do!
Old Mar 30, 2005 | 08:35 PM
H22A EG6's Avatar
Default Code 16 what to do!
ok so here is my deal i came home for a diverstiy conference and all the sudden my car is like running on 2 cly so i jump the ecu and get code 16! fuel injectors what can i do! i need to get back to school on thurs night can hthis be fixed this quick?
can it only be the injectors? what other injectors are compatible?
thx as always you guys are my heors!
Old Mar 30, 2005 | 08:54 PM
H22A EG6's Avatar
Default Re: Code 16 what to do! (H22A EG6)
it would run like total *** and then kinda rough and once like it never happened
could it be the ecu, wiring, or the injectors?
oh and it was raining like a bitch when this happened but i was not in any puddels or anything
Old Mar 30, 2005 | 08:56 PM
WhiteGSR95's Avatar
have a dmm? if so check your injectors
Old Mar 30, 2005 | 08:59 PM
H22A EG6's Avatar
Default Re: (WhiteGSR95)
dmm??? how do i test them?
Old Mar 31, 2005 | 07:18 PM
H22A EG6's Avatar
Default Re: (H22A EG6)
i guess it is fixed now... every once in a while it will act up but other wise it was like it never happened...
Old Mar 31, 2005 | 07:42 PM
jdm_cars's Avatar
maybe you should remove them and clean the injectors. Another thought you can do is to run some sort of Fuel System cleaner in your car, like BG44K which is great.
Old Mar 31, 2005 | 07:53 PM
LSvtec03's Avatar
Default Re: (jdm_cars)
i just had this problem with my lsvtec in the crx. i changed the fuel filter and put some lucas injector cleaner in the fuel tank. i have had no problems since. (this was about a month ago). also, i had this problem 50% of the time when i drove the car, so considering i haven't experienced this again for over a month so far, i think it's safe to assume that it's fixed.
lamesa
Jan 2, 2015 04:06 AM
MUGEN_EG95
Sep 3, 2008 08:57 PM
SkIp_Civic_Ek6
Jan 17, 2007 07:37 PM
redrocketgsr
Aug 19, 2004 11:13 PM
delux247
Jan 28, 2004 11:48 AM
