Clutch problems?
When coming out of 1st gear, my car shakes from the rgiht front side. It feels like the tranny. When the clutch is out it makes a kind of cricket noise, like the throttle bearing bad... Also, when i take into high gears the shifter gets stiff in gear. This all happened after a win against a 2002 Mustang GT. Since then my 3rd, 4th and fifth sometimes grind. I thought it was the motor mounts with the shaking. So, i swapped them out, but got no positive feedback. I know from it not chirping in 2nd and grind ing sometimes in gear it is the clutch... but is the shaking another problem???
Could be a clutch problem but the right side of the car shaking
definetly not sounding good.
I hope for your sake its just a clutch but good luck.
Bump, also interested.
definetly not sounding good. I hope for your sake its just a clutch but good luck.
