Clutch Problem
Old Oct 15, 2001 | 01:20 PM
OgunplayGSR's Avatar
Default Clutch Problem
I've been noticing recently that it's been harder for me to change gears. This morning I was leaving for class and I couldn't get my car into first with the engine running. When I had the car off, I could shift smoothly. I had it towed to a transmission shop and they said that they think the pressure plates in my clutch have collapsed and they want to replace the whole clutch and charge me $450 for labor and $300 for parts. Is there any alternative that might be cheaper and how much do aftermarket clutches usually run?
Thanks
Old Oct 15, 2001 | 01:23 PM
Web_Head's Avatar
New User
Default Re: Clutch Problem (OgunplayGSR)
Check your clutch fluid resivor and make sure there is fluid in there. If not then your master cylinder and/or slave cylinder could be leaking. That could cause the problem you are experiencing. How many miles are on your car?
Trench
Old Oct 15, 2001 | 01:28 PM
Default Re: Clutch Problem (Trench)
Yeah my clutch fluid reservoir was still full. And I just replaced the master and the slave cylinder not too long ago so there isn't a leak. I do have 127K on my car tho.
Old Oct 15, 2001 | 02:15 PM
I just talked to the guy at the shop again and there was also a leak in the slave cylinder.
Anyone know where I can get an ITR clutch? I did a search and someone said godspeed motorsports had em but I cant find anything on the website.
Thanks
b20vteg757
Jun 26, 2015 01:35 PM
dgerej2
Oct 1, 2009 07:16 AM
JLSpeed
Aug 15, 2009 07:22 PM
94dxt
May 8, 2003 06:25 PM
Hard2Find
Mar 12, 2002 03:17 PM
