Clutch problem
Old Nov 24, 2013 | 04:43 PM
Alope's Avatar
Default Clutch problem
Hey guys,
So I'm clearly a new member of the site, but I'm very familiar with it, I've used this page to help me out with other problems I've ran into with my teggy. So the problem I ran into about three days ago, my clutch started to lose pressure. I was able to drive it for the next couple of days. I tired to start my car last night, and I wasn't able to get the car in gear. I couldn't engage any of my gears, I've never had any problems with my clutch before.
Info on the Teg.
B18B1 original motor
139k miles
Stock
Original clutch
Thanks guys.
Old Nov 24, 2013 | 05:00 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Clutch problem
You most likely have a leak or a bad part somewhere in the hydraulic system.
See if there's fluid left in the clutch fluid reservior. If not, find out where it's going. Check behind the clutch pedal (inside the car, under the dash). Or check for an external leak.
You will need to replace the bad component and bleed the system.
Old Nov 24, 2013 | 06:09 PM
Alope's Avatar
I have fluid in the reservoir, it's just below the min line. So if it's a leak, it must be a small leak I'm guessing. Would replacing the whole clutch fix the problem, because I've been wanting to put a new clutch in anyways.
Old Nov 24, 2013 | 06:15 PM
B serious's Avatar
No. You would have to fix that in addition to the clutch. The clutch assy. Itself is totally different than the hydraulic clutch release system.
Old Nov 24, 2013 | 06:55 PM
mouab18c1's Avatar
Try bleeding your hydro line again. Also look for leaks at the master cylinder and slave cylinder. Did the clutch slip before this happened?
Old Nov 24, 2013 | 07:02 PM
Alope's Avatar
No the clutch wasn't slipping, I had no problems with it. Until a couple days ago when the clutch pedal started losing pressure.
Old Nov 24, 2013 | 08:10 PM
B serious's Avatar
Your master or slave cylinder might have gone bad. Iduno why the clutch slip question was asked...but the hydraulic system is for releasing the clutch. Not engaging it. So clutch slip would have been another issue altogether.
If you're missing fluid....check under the dash where the clutch pedal attaches to the firewall. I'm fairly sure you'll find fluid there.
Old Nov 25, 2013 | 12:28 AM
mouab18c1's Avatar
Clutches don't just give out randomly. Knowing if the clutch is slipping eliminates the clutch being worn out unless a spring popped out. Process of elimination. But what do I know....
Old Nov 25, 2013 | 02:22 PM
Alope's Avatar
I get where you're coming from, my clutch didn't randomly go out though. I stated that it had been starting to lose pressure for the past week and it wouldn't engage the gear until I had the clutch press more than half way down. I have fluid in my reservoir, it's below the min line though.
jrock1234
Jul 26, 2011 01:26 PM
always smooth
Jan 25, 2008 10:19 AM
B18EG6
Feb 20, 2005 07:16 PM
onyx00
Dec 11, 2004 02:56 PM
94acurals
Nov 29, 2001 05:14 PM
