clutch problem???
Old Mar 23, 2009 | 04:47 AM
phoshyzzle's Avatar
Default clutch problem???
I just put my car back together. It has a competition clutch stage 3 clutch with fidanza 7.5 lbs flywheel. The motor is freshly rebuilt as well. I was driving normally trying to get the clutch broken in. I was in 5th gear going about 55 when the car just stops moving. The car stays in gear and the engine is still on. When I hit the gas and the car is still in gear the car goes nowhere. I pulled over and I checked the shift linkage and it was still on. I noticed I was leaking something. I couldn’t tell if it was from the transmission or the axle. When the car was off for a while I got back in the car and tried again. I put the car in first and it started moving. But when I shifted to second, it went in and the clutch was out but it didn’t go anywhere. What could it be?
Old Mar 23, 2009 | 05:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: clutch problem???
Check your clutch MC and slave cylinders. Could also be a problem with the TO bearing or release fork. Those release forks are a PITA to get back on properly. Are you sure you got it on there correctly?
Old Mar 23, 2009 | 08:01 AM
phoshyzzle's Avatar
maybe not, i guess i have to take it back down and check, i mean everything was fine for 77 miles. clutch master and slave cylinders are brand new, the slave cylinder goes in and out i can feel it, and the master cylinder isnt leaking at all. im going to take it down today and see whats going on.
Old Mar 23, 2009 | 12:35 PM
phoshyzzle's Avatar
axle popped out.
Old Mar 23, 2009 | 03:11 PM
ruskiy's Avatar
glad it wasnt anything internal
Old Mar 23, 2009 | 03:20 PM
Bluesiff's Avatar
I don't think it's your clutch. My first question is is it an LS or GS transmission. If so with what your desribing it sounds like the same problem I had with my B series. The change assembly in your transmission is either worn out or broken. It's a $120 part and it's easy to replace in the tranny if your comfortable with getting inside the box. The LS/GS change assembly's are known to be really weak/ fragile. I'll include some images of the layout and my own broken assembly. The part is labeled #4 on the diagram. The part# 24400-P21-020. Hope this helps
-blue
beany
Aug 23, 2007 02:55 AM
BB409
Jan 4, 2007 06:21 PM
GoKOOLjeff
Nov 5, 2006 09:01 PM
93civcx
Jun 18, 2004 06:25 AM
hybrider
Aug 3, 2002 06:20 PM
