clutch problem?
Old Oct 5, 2007 | 04:34 PM
matryx's Avatar
Default clutch problem?
Hi, I got a 1996 GSR and my car is starting to act up. I'm not sure what is the problem but I think its probably the clutch.
When I start the car and try to be it into first or any gears it won't work. It just doesn't want to go in.
I turn it off and go through the gears fine. Start it up again and put it into first, when letting off the clutch the car shakes like its going to staff out while I'm giving gas still. While this is happening I try to put it in neutral but its difficult also.
Anybody have any idea what the problem is here. The problem is hard to describe. Since I can't drive it anywhere I won't be able to get it to a shop and why I come here first to get some opinions of the problem.
Old Oct 5, 2007 | 10:31 PM
posHonda's Avatar
Most likely the clutch. Check the fluid level too and you can also try bleeding it out.
My guess is a spring on the disc popped out.
Old Oct 6, 2007 | 03:33 PM
SnaveZ's Avatar
it also sounds like that your fluid lines have air in it...
like iVteC_PoWeR said, check the fluid, and bleed it out, see if you have a leak. That could also be the problem...
Old Oct 7, 2007 | 05:55 AM
vladd's Avatar
Default Re: clutch problem? (matryx)
its probably the clutch. a buddy of mine had the same problem, turned out the clutch was torn apart (iirc there were some rivets popped out or something).
Old Oct 7, 2007 | 01:26 PM
matryx's Avatar
Default Re: (SnaveZ)
I just went out and bleed/flush the clutch fluid. Start her up and still can't put her into any gear with the clutch down to the floor.
So I guess I got to go look for a new clutch now. Going to do some research on which one I should get, but if anyone have any suggestions for a daily driver, please do.
Do you guys suggest getting a lighter flywheel or should I just get it resurface?
Old Oct 7, 2007 | 01:42 PM
SleeperGSR's Avatar
Default Re: (matryx)
i would get a lighter one, but it depends on your budget and what you want to do
Old Oct 7, 2007 | 01:45 PM
ringooo's Avatar
hey, i have the same problem, let me know your solution!
Old Oct 8, 2007 | 08:14 PM
mugenr#1011's Avatar
Default Re: clutch problem? (ringooo)
yeah so do i! im debating on getting the toda clutch and flywheel if bleeding the system doesnt work.
Old Oct 8, 2007 | 08:19 PM
posHonda's Avatar
If youre not looking for any serious power than an Exedy Stage 1 clutch with a 12lbs flywheel should work great. Or if you wanna save money just get your current flywheel resurfaced.
Old Oct 8, 2007 | 08:24 PM
blkteggy's Avatar
Default Re: (iVteC_PoWeR)
or maybe it could need a new slave and master cyl. that **** happend to me and i ruined a new clutch and found out that it needed new master and slave cyl. so i had to buy another new clutch.
Old Nov 2, 2007 | 03:30 PM
matryx's Avatar
With a new clutch install I've been hearing the rear main oil seal should be replaced also. I can't seem to find it though. Doesn't it go by another name? The only other one I see if the Input Shaft Seal. Anyone know?
Old Nov 2, 2007 | 05:08 PM
bjones's Avatar
first try bleeding the clutch, then if that dont work try replacing your slave cylinder, then if all falls i would say ur clutch
applejak_2000
Honda Civic (2001 - 2005)
Jan 28, 2017 12:22 PM
marcin
Jun 5, 2009 11:19 AM
94GSR ArucA
Jul 19, 2006 02:23 PM
94acurals
Nov 29, 2001 05:14 PM
