Clutch Install = MTF Change?
If I'm changing my clutch and flywheel am I going to have to or should I change my manual transmission fluid? Please Get Back To Me ASAP.
Ben
Ben
Re: Clutch Install = MTF Change? (Dirty GS-R)
Re-use it?
You've already spent X amount of dollars for the new clutch, pressure plate, throw out bearing, maybe even getting a new flywheel and you're not gonna get 2 quarts of MTF?
Re: Clutch Install = MTF Change? (Jesse H)
theres no point of reusing it...since u r takin out ur tranny u might as well put in some new fluid...its just convienent (wrong spelling? lol)
Re: Clutch Install = MTF Change? (Fuuma0083)
Well, we ran out of time. We got to the point where you have to pull the driveshafts off, ran into a problem, talked to a mechanic, and then decided we didn't have time and put it back together. So:
Failure:
Installing Clutch
Installing Flywheel
Installing JDM ITR Rear Sway Bar
Success:
Installing Fluidyne Radiator
Changing MTF
Ben
Failure:
Installing Clutch
Installing Flywheel
Success:
Changing MTF
Ben
