PROBLEM with clutch now
i was driving today and all the sudden it was hard for me to put the car back into gear even with the clutch all the way down also the clutch pedal doesnt even come all the way back up..it has sooo much play in it ...almost like the clutch is to the ground...and the engagment is like 1" from the floor(happened the same time while driving)...also theres chattering still going on... check this post previous post https://honda-tech.com/zerothread?id=294854 ....i dunno how i got home but i did :WHEW:...what can it be a throw out bearing came off?..but why the clutch has no pressure?...help me out
[Modified by cr00klyn718, 12:28 AM 11/28/2002]
[Modified by cr00klyn718, 2:03 AM 11/28/2002]
[Modified by cr00klyn718, 2:09 AM 11/28/2002]
Re: PROBLEM with clutch now (cr00klyn718)
Check the clutch slave. If that's not the problem, then try bleeding the clutch and replace with all new fluid. It could be your clutch master cylinder going bad. If you need to replace these parts, go to http://www.hondaautomotiveparts.com they are a direct honda parts distributer and usually have some good prices if you want oem equipment. Good luck and hope you figure it out.
It could be that the throwout bearing came loose or off. I had a problem with my four door like that, but it was the wire clip that held onto the clutch fork that was the problem. What kind of tranny is it? The chances of the throwout bearing coming off the clutch fork seems kind of awkward since it hooks on and also goes around the output shaft that goes into your flywheel. But all in all, check everything else first before you take the tranny off. Try pushing on the clutch slave manually and see if it compresses. If nothing happens then the slave is either bad or clogged. Good luck and hope you figure out what's wrong.
Re: PROBLEM with clutch now (JDMH22HATCH)
well i found out what the problem was today mourn...went to check if their was ne clutch fluid..and guess what?...NO clutch fluid....so i put some in and pumped the clutch and it worked...::WHEW::...still got a chatter noise though. ..but at least i fixed that prob ...for now . thanks for the replies jdmh22
Re: PROBLEM with clutch now (TheKidd)
ok the car gets into gear now....but the clutch still on the soft side again..and clutch grabs like crap....and chatter comes around 3-4rpms ..i think i should still get a new clutch just incase....inputs welcomed
ok i decided that imma stil get a new clutch...thinking about gettin cm...where can i find the best price for one?
Well my clutch went a couple of weeks ago and I picked up a CM's Stg. 4 from Import Horizon this week. Paid for it last Thurs and got it this Monday. Good service and cheap price I'm putting it in today or tomorrow so hopefully all should be good.
oh yeah had the same problem..looking into getting a new clutch....i heard act's are pretty good...also there might be a leak in the clutch master or slave cylinder....check to see if it's leaking in either one...mine was leaking from the master and leaking into the pedal...good luck
Re: PROBLEM with clutch now (brokestock)
well i bleed the clutch this past weekend and the clutch pressure is good now.....but yesterday night i notice that in everygear around 3-5rpm it makes a chatter/metal scraping type sound....what the hell is causing this or what can it be...its just annoyin the hell out of me not to know what causing it ....hope by ordering a new clutch will solve this.
