clean lights
Old Sep 25, 2002 | 10:44 PM
95integrags-r's Avatar
Default clean lights
I was wonderign how/if you could clean your front headlights and blinkers. I was lloking at that pic of the PY type r with the monster intercooler.... and the lights look REALLY good. clear. and sharp. mine seem a little faded and dirty. how do I get that crytal clear sharp look back?? thanks
-chris
Old Sep 25, 2002 | 10:52 PM
Mase's Avatar
Default Re: clean lights (95integrags-r)
hehe hows that for clear?
i took that pic w/ those headlights were only about 3 hours old.......acura replaced both of my headlights because they started to crack inside.......ive heard plastic polish works good.
Edit: doh, now i look at it, they arent that clean
[Modified by CDooMe2, 11:53 PM 9/25/2002]
Old Sep 25, 2002 | 10:57 PM
Default Re: clean lights (CDooMe2)
yea.....thats what I want them to look like. do you know how much new headlights and blinkers are??
Old Sep 25, 2002 | 11:15 PM
Chris's Avatar
New headlights are around $350 each side for a G3. Im sure the blinkers are ~$100.
Old Sep 25, 2002 | 11:29 PM
Default Re: clean lights (Chris)
AKKKKKK so 900 dollars for all new lights??? that is crazy..... should just get a JDM conversion if I am gonna end up spending THAT much
Old Sep 25, 2002 | 11:34 PM
GSRrR's Avatar
Wet sand it then polish it. Comes out to look pretty much like new. I think it was like 400 or 800 grit.
Old Sep 25, 2002 | 11:52 PM
Default Re: clean lights (GSRrR)
how would I do this???
Old Sep 26, 2002 | 12:20 AM
Quik Chris's Avatar
Yeah, what kind of polishing are we talking about here??? I'd use finer than 400 grit, maybe 1000.
Old Sep 26, 2002 | 12:21 AM
Mase's Avatar
Default Re: clean lights (Midori Shinkansen)
****, id use way way fine grit.....1200 isnt even good enough to polish my IC
Old Sep 26, 2002 | 12:34 AM
GSRrR's Avatar
hmm let me check and get back to you guys. Friend did this on his es300.
Old Sep 26, 2002 | 12:45 AM
GSRaCeRbOI's Avatar
theres been several threads on this.. some listed to use plastic polish.. 3M Rubbing Compound.... others said to use glass polish.. some said to wetsand it starting from a higher grit.. then down to a real fine grit... and someone even mentioned using toothpaste..
I haven't personally tried any of this.. but let me try to find the links for you.. hold up..
EDIT: found these in a search..
https://honda-tech.com/zerothread?id=263412
https://honda-tech.com/zerothread?id=193973
[Modified by GSRaCeRbOI, 1:51 AM 9/26/2002]
Old Sep 26, 2002 | 03:41 AM
Pineapple Devil's Avatar
Default Re: clean lights (GSRaCeRbOI)
there is some stuff called Nu-Lite that I used on my mustang headlights. I guarntee you it will do better than anything listed. You'll need to take the front clip off to take the headlights off, but its worth it. Its acid that eats all the yellow and stuff off then its got a polish with it. I ordered mine from Mustang Part Specialties.
http://www.stangparts.com/home.cfm?s...products/index
click on Lights, and its on page 4. Its called Nu-Lite
[Modified by Pineapple Devil, 2:02 PM 9/26/2002]
Old Sep 26, 2002 | 07:01 AM
Dan GSR's Avatar
Default Re: clean lights (Pineapple Devil)
I still don't know how to do this either....my projectors are dirty too
I need to get inside and clean it out......help
Old Sep 26, 2002 | 08:11 AM
NiCkArInO's Avatar
thats what im sayin
Old Sep 26, 2002 | 08:44 AM
Chris's Avatar
If you plan on using the sandpaper method (it works) start with at least 1500 and work up to 3000. then polish with an orbital. Be careful not to burn them!
Old Sep 26, 2002 | 09:08 AM
StyleTEG's Avatar
I would be careful with wetsanding if you don't know what you are doing
You should be able to get great results just with a good polish (3m plastic polish, car polish, etc). Toothpaste has abrasives in it, so it acts like a polish.. but the consistancey is pretty poor so I would stick to something automotive related.
Old Sep 26, 2002 | 11:30 AM
vimsen's Avatar
If the outside needs polishing try a Scratch remover or Glazing Compound or a mild abrasive kitchen cleaner. I apply scratch remover or glazing compound on the glass and wipe it off when I am waxing the car. Works well.
You can try clean compressed air to blow out any dirt of inside.
Old Sep 26, 2002 | 11:56 AM
ALF's Avatar
ALF
I just used toothpaste on mine a week ago and it WORKS! Looks just as new and shiny as my other one. Before you go out and buy something, try regular toothpaste. I used a thick paper towel to apply and buff. The results definitely surprised the hell out of me.
Old Sep 26, 2002 | 12:26 PM
Cramerox's Avatar
Default Re: clean lights (ALF)
[QUOTE]Follow this process.... worked great on my 95 DC (r.i.p)
Materials you will need:
1. 3M 1000 grit sand paper.
2. any type of car polish.
3. any type of car wax.
4. a tupper-ware bowl filled w/ water ( if you know about wet-sanding ... u see where im going w/ this)
Procedure:
1. Remove you headlights off the car .... Yes we know takn' off the bumper is ever stonners nightmare!
2. Fold you 3M and wet it in the tupper-ware bowl and start sanding your headlights in a circular motion for atleast 10-15 min. on each light. Feel free to wet the sand paper time 2 time.
3. Assuming you're done w/ all the lights you will notice that all your headlights look like ****. Don't worry you have just done the 1st step.
4. Now time for the polish. You want to use the polish 1st since it is somewhat abrasive. Polish each light for about 5 min. each.
5. Asumming you are done polishing all the lights, Time 2 wax. It is the same process as the polish.
6. Put the **** back on your hooptie and voila' you lights look brand new .... and you saved atleast $200 bones ..... and if you got the cash get some new bulbs
Old Sep 26, 2002 | 02:48 PM
Default Re: clean lights (Cramerox)
alright. that meakes me happy.
Old Apr 8, 2003 | 08:40 PM
bitzbp's Avatar
I did this to my Supra headlights with 1500 and then 2000 grit paper followed by plastic polish, and everyone thought the lights were brand new. Certainly worth a try if your gonna go spend 400+ on new lights
Old Apr 8, 2003 | 08:45 PM
usdmcrx's Avatar
Default Re: clean lights (bitzbp)
man....all i used was some universal polish for metals and it worked...i wouldnt recommend sand paper...all i used was the polish and towel!
Old Apr 8, 2003 | 09:40 PM
Default Re: clean lights (usdmcrx)
3:48 PM 9/26/2002..... hahaha holy **** that post was old, I was like what the hell! haha. i still havent done n e thing about it either thanks for the advise though
-chris wagner
hondaj05
Sep 3, 2006 06:46 PM
chartpak
Jan 23, 2005 04:02 PM
Ideal
Jan 1, 2004 07:40 PM
acatak
Apr 29, 2003 05:31 AM
keebler65
Feb 28, 2003 04:44 PM
