Cleaning Headlights
Old May 25, 2002 | 07:32 PM
acatak's Avatar
Default Cleaning Headlights
Anyone know how to get insdie the headlights to clean them?
Old May 25, 2002 | 08:37 PM
dohcsideSi's Avatar
Default Re: Cleaning Headlights (acatak)
you really can't w/o breaking the seal....and then wait till it rains
Old May 25, 2002 | 09:15 PM
Madness's Avatar
are they just foggy looking like all old teg headlights?
mine cleaned up real nice with some 3M hand glaze (a microfine paint polish) and a little bit of effort
hope that helps -- i hate seeing something so ugly which is so easily fixed
Old May 25, 2002 | 09:20 PM
Calavera's Avatar
Default Re: Cleaning Headlights (dante_420)
Are you saying you just applied that 3M polish on the outside of the headlights?
Old May 25, 2002 | 09:35 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Cleaning Headlights (Calavera)
I wetsanded my headlights with grits from 320 up to 2000 grit, then polished w/ 3M rubbing compound, then finished off w/ some plastic polish. They look real nice now. You should take the bumper off in order to do this.
Old May 25, 2002 | 11:51 PM
Honda F1's Avatar
Default Re: Cleaning Headlights (PatrickGSR94)
No, what you need to clean the outer lense on the lights is 3M plastic cleaner and polish. It gives the lights the new crisp look and removes light scratches from the lense. Trust me it works. The only retail place I have seen that carries it is Napa.
Old May 26, 2002 | 05:28 AM
Madness's Avatar
yes -- just use to 3m polish directly on the outside
they're plastic polish also works really well , although i used the hand glaze b/c that is what i had on hand -- it is designed for removing 1500 grit paint swirls after color sanding, so it is very fine
Old May 26, 2002 | 12:01 PM
acatak's Avatar
How do you clean inside the headlight???? mine are all dusty
Old May 26, 2002 | 12:04 PM
SIK IN DA HED's Avatar
New User
flush it out with water.
Old Apr 29, 2003 | 04:46 AM
10K2HVN's Avatar
Default Re: Cleaning Headlights (SIK IN DA HED)
you might want to use distilled water or soft water so it doesnt leave spots when it dries...sorry to raise this post from the dead, i was just searching and found this thread and thought i might reply... wow this thread is almost a year old!!! -TECH
Old Apr 29, 2003 | 05:31 AM
vti-2's Avatar
I've actually got small fragments of glass inside one of my lights, i bought the car like that. I assume a little bit of the edge has cracked and fallen in but i can't see any damage from outside. Would i literally have to take off the front bar to remove the lights or are they different on Australian cars?
KangTa
Jan 2, 2007 03:58 PM
bertyman
Honda S2000
Oct 12, 2005 04:38 PM
thomst4R
Jul 24, 2005 04:58 AM
Ideal
Jan 1, 2004 07:40 PM
streakz
Jun 13, 2003 02:26 PM
