Common Integra problems..
Old Mar 3, 2007 | 09:13 PM
Jimmy's Avatar
Global Moderator
Default Common Integra problems..
Just recently aquired my first integra which is a '94 integra RS.. It's got a couple little bugs i'm wanting to get straightened out..
The car has power windows And the driver side window rattles while driving, Do i need to just pull the door panel off and tighten a couple 10mm bolts up or due to it having power windows is there still a regulator or what?
Also the driver side window motor comes up and down perfect but sometimes it get's stuck and acts like it doesnt wanna come down.. (while it's raining and slippery it rolls up and down fine as well)
Do the window tracks need to be lubed or what and if so what is the best **** to use?
Old Mar 3, 2007 | 11:17 PM
Jimmy's Avatar
Global Moderator
28 views, no replies..anyone?
Old Mar 4, 2007 | 02:50 AM
98GSRDC2's Avatar
Default Re: Common Integra problems.. (Jimmy)
you have 5614 posts but its your first integra?
Old Mar 4, 2007 | 07:26 AM
dragonfly2k3's Avatar
Default Re: Common Integra problems.. (98GSRDC2)
not to be a dick but look at his sig. He deffinately not new to hondas, just integras. And somebody should prob help out with what lube to put in the tracks because both my window and my sunroof squeek and hop.
Old Mar 4, 2007 | 07:46 AM
DELPHI's Avatar
Default Re: Common Integra problems.. (dragonfly2k3)
Window problems are all over the place. I only have minor rattling when the windows 1/2 way down on the drivers side. I also take some time every few months to re-lube all the gaskets and mechanical parts with white lithium grease. Seems to be working well.
Here are some other options to look at that may be your problem...
http://www.team-integra.net/se...D=552
http://www.team-integra.net/se...D=596
- When you open everything up check for random rubber gaskets/strips down at the base of the door skin/frame and see where they came from and replace. Sometimes they fall out of place and the rattles really get serious after that happens.
Old Mar 4, 2007 | 07:58 AM
vnguyen850's Avatar
Default Re: Common Integra problems.. (DELPHI)
i've had the same problem and what i did was took apart the door panel tighten all the tracks and whatever else i could get to in there. then on the outside edge of the window on the backside i sprayed some type of aerosol oil and from then it seems to be working fine thus far. you may want to use a more heavy grease because for some reason that aerosol oil doesn't last long. my .02
Old Mar 4, 2007 | 09:49 AM
Blahblah718293's Avatar
Default Re: Common Integra problems.. (vnguyen850)
it really is a common teg problem, my windows are like that and i didnt know fixing it would be so easy, you just take off the panel and tighten some bolts? also my sunroof has stopped oppening lately, you hit the button and you can hear the motor push and it lifts slightly but i guess its caught on the weather stripping or somthing.
Old Mar 4, 2007 | 09:55 AM
IntegrasAreBest's Avatar
great info! im going to do this.
Old Mar 4, 2007 | 10:09 AM
JoePSI's Avatar
Default Re: Common Integra problems.. (IntegrasAreBest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Just recently aquired my first integra which is a '94 integra RS.. It's got a couple little bugs i'm wanting to get straightened out..
my 95 gsr had the same issues. I did just as what everyone else is saying. I tightened the bolts, especially the bolts that hold the window crank secure. I also put white lithium grease on the guides and the crank, this seemed to help the window operate a lot more smoothly.
Old Mar 4, 2007 | 12:34 PM
Jimmy's Avatar
Global Moderator
thanks for all the replies, i'm gonna pull the door panel off and fix this ****..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GSRDC2 &raquo;</TD></TR><TR><TD CLASS="quote">you have 5614 posts but its your first integra?</TD></TR></TABLE>
Since when did posts have anything to do with what car you have? If i post ***** and get 10,000 can i get PY ITR? BUT in all reality i've been here for YEARS.. I've always stuck with the 92-95 civic chassis.. This is my first teg and i don't plan on gettin rid of it
thanks again.
Old Mar 4, 2007 | 08:35 PM
02Type-S's Avatar
Trades A lot!!
as far as the window sticking sometimes, just use some silicon spray on the tracks and it will go away. My passenger window on my integra stuck and when i did that it never did again. I have a whole can of it left over if you just want to use it.
Old Mar 4, 2007 | 10:14 PM
waddy41's Avatar
weird...my driverside window is slower than the passenger side......
Old Mar 4, 2007 | 10:21 PM
20ls01's Avatar
wtf this is the stupidest comment ever....high post means you have to have an integra?
Old Mar 5, 2007 | 06:07 PM
Jimmy's Avatar
Global Moderator
Default Re: (02Type-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02Type-S &raquo;</TD></TR><TR><TD CLASS="quote">as far as the window sticking sometimes, just use some silicon spray on the tracks and it will go away. My passenger window on my integra stuck and when i did that it never did again. I have a whole can of it left over if you just want to use it. </TD></TR></TABLE>
lmk when
Old Mar 5, 2007 | 10:52 PM
Jimmy's Avatar
Global Moderator
Silicone spray most def fixes the sticking window problem.. thanks again brad!
As for the rattle, i'm gonna haft to pull the door panel off
Old Mar 6, 2007 | 09:09 PM
italianchooch88's Avatar
for some reason the passenger side deffinatley rises slower than the drivers side.i have the same problems starting with my windows.just take care of it soon cuz when the window falls off the track its a bitch
Old Mar 7, 2007 | 12:08 AM
dezerte's Avatar
Default Re: Common Integra problems.. (20ls01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">
wtf this is the stupidest comment ever....high post means you have to have an integra?</TD></TR></TABLE> LOL
onepoint-gsr
Texas -OK -LA (Sales)
Jan 12, 2008 03:21 PM
rusureboutdat
Jul 13, 2004 08:30 PM
