check engine light question
Old Apr 4, 2004 | 11:34 PM
pbizzlegsr's Avatar
Default check engine light question
today a friend and i tried to swap out the stock cat to install a carsound cat from ipsracing..we unplugged and switch the two 02 sensors and eveyrhint but it turns out it didnt fit..so then we swaped the stock back on and next thing you know check engine light came on when we started the car..i know for sure it has to do with the 02 sensor bc it was touched and taken out ..so then we unplugged the negative terminal of the battery to reset everything and the light was gone..do i have anything to worry about since the light seems to be gone now?..if there was still a problem it would come back right?..thanks
Old Apr 4, 2004 | 11:36 PM
xplanetearth420x's Avatar
Default Re: check engine light question (pbizzlegsr)
if it comes back check out your o2 sensors make sure nothing is wrong with them
Old Apr 4, 2004 | 11:46 PM
pbizzlegsr's Avatar
Default Re: check engine light question (xplanetearth420x)
and if it doesnt..im fine?
everlasting1832
Feb 10, 2005 11:23 AM
Nitto
Aug 10, 2004 07:11 PM
nexus da9
Mar 2, 2004 03:36 PM
Memo6453
Feb 11, 2003 10:26 AM
Ludeboi
Aug 31, 2002 04:54 AM
